Results 1 to 9 of 9
- Aug 2015
- 862
October 22nd, 2015 03:32 PM #1Tanong lang ako opinion nyo mga sir. Kung naka yuko ung altis ko sa driver side, mostly sa front. Anong inche check ko una? Shocks? Spring? Kaunti lang pero kaka bother kasi e. Any other things worth checking para di madaya sa diagnosis sa shops. Thank you.
- May 2015
- 280
October 22nd, 2015 03:48 PM #2Sir kung naka-aftermarket springs ka, check mo ung pagkakaupo nun spring sa shocks while car is jacked-up. Baka na-disalign lang. Pero kung wala ka naman pinapalitan pero naging ganyan, busted shocks yan.
You can also check if busted ang shocks by pushing the car downward sa driver's fender side and check how the car bounces. I-compare mo sa kabilang side kung same sila ng behavior. Please do this carefully, baka mayupi mo yung body.
Prepare your budget for 1-pair of front shocks. Di po advisable magpalit paisa-isa. Dapat per pair. HTH
- Nov 2008
- 641
October 22nd, 2015 03:54 PM #3Normally sir pag di na align yung height, its because worn-out na yung coil spring. Mas madaling malundo yung sa driver side kasi yun ang laging may load, unlike sa kabila na hindi lagi may pasahero. Pag pinalitan, mas mainam na magkasabay (kaliwa at kanan) para pantay. Kung di naman gaano bagsak as compared sa kanan, pwede kahit sa sunod na lang, medyo mahal kasi pares nun. Check nyo din yung shock absorber, kung loose na kasi yun, it amplifies the deterioration of the springs.
October 22nd, 2015 04:01 PM #4
First culprit would be the shocks. You'll have to take it up on a lifter to see well.
- Aug 2015
- 862
October 22nd, 2015 05:04 PM #5Thank you sa mga advice nyo ha. Yup all stock ang altis ko, baka palitan ko nalang din both shocks sa front, hindi na rin masama 8 years na ung stock shocks no? Sana nga yun na.
Mejo nakaka praning kasi minsan di pantay ang tingin ko sa dash parang minsan akala ko flat tire.
October 22nd, 2015 05:44 PM #6
October 22nd, 2015 06:18 PM #7
- Aug 2015
- 862
October 22nd, 2015 07:38 PM #8
- Oct 2013
- 2,537
October 22nd, 2015 08:34 PM #9
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
