Results 1 to 7 of 7
- Jul 2009
- 1
July 20th, 2009 10:10 AM #1Hi Guys, I need your help. Ung CRV ko with year model 2004 e me galaw ung steering wheel even ang takbo ko e mga 40kph lang. Nag pa wheel alignment ako at digital pa ung gamit e wala naman nakita. San ba maganda magpa check up ng steering.
July 20th, 2009 10:36 AM #3
wheel balancing is the first option. also try to exchange your two front tires. pag hindi lumipat yung wiggle/shaking, there are other suspension related issues there.
check also your tire pressure kung pareho.
- May 2009
- 119
July 20th, 2009 04:03 PM #4during idle or nakapark meron po bang vibration?kala ko po kasi xwind ang car nyo kasi normal lang ito for xwinds...
check nyo gulong nyo baka may bukol or oblong if running nyo ramdam ang vibration...
kapag nakaidle lang check nyo engine mount/support baka may worn out na...
- Jul 2009
- 57
July 20th, 2009 04:55 PM #5parang ganyan yung nissan ko dati sir, pag medyo mabilis na takbo nun or around 80-90 siguro nun e nagshashake manibela ko.. chineck nila yung components na naka attached sa gulong ko sa harap, then yung tie rod end, hindi na firm yung bushing kaya gumagalaw kunte kaya pag matinding pressure na sa steering e nagshashake na.. pero i don't really know kung ganun po sa inyo, kasi sabi mo 40 pa lang e feel mo na.. just an idea
- Feb 2008
- 325
July 20th, 2009 07:10 PM #7
also try to check the brake calipers kung mahigpit. may kilala ako, hindi makita yung source of shaking/wiggle... tapos nagpalit ng brake pads, nahigpitan yung mga calipers, nawala ang wiggle.
While ford does not specify time-based intervals for The AT ZF specifies a 8 year interval for the...
Ford Everest 2015
