Oil leak from shocks should be evident at the shaft and exterior tubes. Madalas kapitan ng alikabok at dumi pag may langis o tagas.
Ang KYB ba may fluid type na shocks? I find the gas type too matagtag for my Lancer EL.
Meron po, ang tanong kung may available na exact length and holes for it.![]()
Amazon And monroe marketing are both in masangkay near recto. Monroe generally has a softer ride than kayaba. But handling is ok. If your ride is on the heavier side use gas magnum by monroe para mas matibay.
im using monroe reflex in my rears. good thing about this brand on the 323 familia is the catch plate is the same height with the mazdaspeed adjustable shocks which is an inch lower than stock.
from my stock tokico gas shocks, i find the monroe softer.
ok kaya monroe para sa pajero? mga how much isa?
dati nag palit ako ng shock kyb sa front.. 1k isa..
now ung likod kelangan ko na palitan, kasi tabingi ung pajero.. parang mababa ng konti ung right side.. possible ba sa shocks un?
ingat lang po sa fakes moroe...
nakabili kami ng fake, akala lang namin mura... ayun... you feel as if nothing is installed at all...![]()
