Results 1 to 10 of 29
- Jan 2003
- 7
January 13th, 2003 01:41 PM #1what are the symptoms of a leaking shock absorber (fluid type)? meron ba talagang liquid type na lumalabas dun sa shock pag may leak na ito? will a leaking shock cause noise while the car is in motion?
January 13th, 2003 01:43 PM #2
rockyme,
Yup, oil will leak out of it. Even good shocks produce sounds sometimes.
January 13th, 2003 01:50 PM #3
Leaking shocks could be easily checked by accumulated moist dust around the rod seal area. It would be better if you wipe of the grimes first then drive a block or two to check for the oil leaks around it.
- Jan 2003
- 7
January 14th, 2003 02:05 PM #4OTEP and UNGAS,
thanks for the great inputs. they are well taken. i'll have my shocks checked soon!
January 14th, 2003 03:38 PM #5
rockyme::: Good luck.
And oh, by the way, what is your ride? And how old is it?
- Jan 2003
- 7
January 14th, 2003 04:49 PM #6ungas, thanks!
i have a pretty old car, a singkit. wanting to install surplus shocks na lang since this is an old car (in fairness makinis pa syang tingnan at matibay pa, aside from the shocks). :D is it advisable to do so?
January 14th, 2003 09:48 PM #7
I would not advise the surplus shocks since you can't ba sure how long they will last. My dad had one installed in our car once at pinagsisihan niya 3 months later. If tight ang budget then go for the good replacements like KYB. :D
January 14th, 2003 11:14 PM #8
hello. :D tama po si roydok. even if mura ang surplus, dont go for them coz you wont have a clue how long they would last. doble gastos lang po to if ever :D goodluck!
- Jan 2003
- 7
January 15th, 2003 09:09 AM #9thanks for the ideas! :wink: any idea on how much would a pair of kyb, gas type cost? saang store ang cheapest? thanks!
- Nov 2002
- 162
January 15th, 2003 09:19 AM #10wats ur car? sa mga lancer more or less 2500 sa likod 1500 sa harap (or baligtad)
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
