Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    Jan 2003
    what are the symptoms of a leaking shock absorber (fluid type)? meron ba talagang liquid type na lumalabas dun sa shock pag may leak na ito? will a leaking shock cause noise while the car is in motion?
    rockyme,
    Yup, oil will leak out of it. Even good shocks produce sounds sometimes.
    Leaking shocks could be easily checked by accumulated moist dust around the rod seal area. It would be better if you wipe of the grimes first then drive a block or two to check for the oil leaks around it.
    Jan 2003
    OTEP and UNGAS,
    thanks for the great inputs. they are well taken. i'll have my shocks checked soon!
    rockyme::: Good luck.
    And oh, by the way, what is your ride? And how old is it?
    Jan 2003
    ungas, thanks!
    i have a pretty old car, a singkit. wanting to install surplus shocks na lang since this is an old car (in fairness makinis pa syang tingnan at matibay pa, aside from the shocks). :D is it advisable to do so?
    I would not advise the surplus shocks since you can't ba sure how long they will last. My dad had one installed in our car once at pinagsisihan niya 3 months later. If tight ang budget then go for the good replacements like KYB. :D
    hello. :D tama po si roydok. even if mura ang surplus, dont go for them coz you wont have a clue how long they would last. doble gastos lang po to if ever :D goodluck!
    Jan 2003
    thanks for the ideas! :wink: any idea on how much would a pair of kyb, gas type cost? saang store ang cheapest? thanks!
    wats ur car? sa mga lancer more or less 2500 sa likod 1500 sa harap (or baligtad)
    Jan 2003
    boybitz,
    lancer, 1990. sa likod problema ko eh. pair na ba yung 2.5K or isa lang? kailangan pair ako magpalit di ba?
    thanks!
    for gas type kyb on lancers it's P2500 ea front and P1500 ea rear. let me know if anybody needs help on getting genuine kyb.
    rockyme::: Never buy those surplus shocks. I have the same point of view with roydok & pajerokid. You will just regret buying those useless shocks. It may sound cheaper but your peso will run as short as you'd expect it.
    I asked an auto supply friend for the price and its almost the same price as zildjian posted.
    2000 each front / 1500 each rear
    hindi ba liquid type yung P2000 for front? kung gas type yan eh ibig sabihin ang mahal pala ng sa amin. heheheh... baka nagkamali friend nyo sir.
    I asked the store, and it was a liquid type pala for 2000 front shocks. :D
    Jan 2003
    thanks to all for the good advices! :D
    zildjian,
    san ako makakabili ng genuine kyb shock if ever me budget na ako? how much naman kaya ang pa-install nito?
    salamat ulit!
    rockyme,
    pwede sa akin or sa atco. free delivery depende kung saan location mo.
    labor price is usually P350 each side. mas maganda painstall mo sa mga shops na may 4 wheel alignment para diretso alignment na.
    Jan 2003
    zildjian, thanks!
    i've also read that you can change the oil seal and replace timing belt. how much would the labor cost? sa tingin ko may leak na rin makina ko kse there's an oil seepage.
    please advise.
    thanks!
    i actually have a mechanic who can do the job though on schedule basis din. labor is P500 for timing belt replacement kaso lang malayo location namin dito sa gentri cavite. kapag sa labas yata ay mga P1000 to P1500 ang labor para sa timing belt.
    Sir Zildjian,
    Naalala mo ba last time nang kumuha ako nang OEM na shock..... hayun kumuha sila sa Toyota Manila Bay. Nong magpalit kami nang gulong (coz na flat) tinitingnan ko yung shock i just found out na yung naka tatak ai KYB. Ito ba talagang brand name na makikita sa OEM na shock or ginulangan naman yung Esmi ko sa CASA?
