Results 1 to 20 of 45
    Jun 2007
    recommend naman kayo ng shop na specialist ng power steering (magaling at mura pa) nakita ko may leak yung tubo ko e gusto ko na sanang paayos bago pa pumutok I-think pressured siya e
    thanks tsikoteers
    Nov 2003
    get the oem ps hose if it is the high pressure hose. if you have it repaired or replaced with a replacement one, 90% yung chance na iingay yan when you turn the wheel.
    Taga san ka ba? Kung around Pasig, Marikina, part Cainta, Antipolo, & QC. try mo 'to:
    Multi-Flex Enterprises
    #223 Amang Rodriguez Ave., Santolan, Pasig (near Mickey's Auto Sound & South Supermarket)
    Tel: 6821491
    Dealer ng mga automotive, industrial hydraulic hoses sila. May mga branch ng casa ng Toyota, Mitsu, Nissan, Honda pati Ford sa kanila kumukuha at nagpapagawa.
    Jun 2007
    thanks sa suggestions niyo mga sirs todo ingay na ng power steering ko
    Aug 2004
    Pakiramdam ko kasi parang sobrang lambot ng steering wheel ko po eh. Parang may play yata lalo na pag tumatakbo. Pwede kaya na rack end pinion clamp bushing ang problem ko?
    question po: after i had my sentra detailed, medyo may maganit na ung steering wheel pagnit-turn (while full stop) at parang mabigat sya iikot. the former (the maganit feeling) sabe sa shop mawawala din daw un. is it because of power steering oil? low na kaya sya?
    wala po kasi akong alam eh. please help me (yet again)
    super thanks po!!!
    Quote Originally Posted by hyperthread View Post
    usually powersteering clamp and problem mo ... the parts is cheap but the labor is expensive ...
    pwede rin yung isang shocks mo sira na so the car is unbalance kasi meron isang instance na sira yung shocks niya ... the steering becomes very hard pero paminsan minsan lang
    FYI: powersteering differs from car to car ...
    pag may leak ang powersteering mo ... may mga repair kit para diyan ... depende what kind of car it is ... usually in banawe area completo sa repair kit and parts ...
    for the reservior kahit anong klase okay lang basta ba fit and walang leak
    for those maingay yung powersteering while turning powersteering hose ang problem mo ... and kailangan mo palitan ang hose mo ng orig or japan oem parts ... not local parts
    and usually recommended na powersteering fluid ang lagay sa steering fluid not ATF especially honda cars which is pretty maselan ...
    hope this helps
    BANAWE AUTO SUPPLY
    regy
    Apr 2006
    Quote Originally Posted by banawe View Post
    regy
    sir, saan po nakakabili ng steering fluid na hindi atf? at anung brand?
    wala kasing ganito sa gas stations eh. atf lagi ang offer nila.
    also, if you are familiar with nissan california's PS cap/gauge, dalawa po ang indicator niya - hot and cold. anu kaya ang susundin ko dun when filling up the reservoir?
    thanks
    maraming powersteering fluid sa market ... castrol, STP, honda has its own powersteering ... basta usually powersteering fluid is malapot konti and whitish in color
    dun ka lang sa cold ... kasi ibig sabihin yan pag running yung car mo it reaches dun sa hot guage ...
    Apr 2006
    thanks regy!
    panu yan kung ATF na ang currently na nakafill up, pwede bang haluan ko agad ng PSF o dapat i-flush muna lahat?
    OT:
    nice meeting you sa phone kahapon. loko yun shop na nagsabing P1900 ang kyb shocks, out of stock pala!
    pero may nahanap padin ako natawaran ko pero mejo mataas na sa 1,900.
    next time sa 'yo na ko kukuha para walang hassle.
    ok tong si regy, matulungin at ok mag-advice!
    try nyo cyclo power steering fluid. yun akin nawala pati yun konting tagas
    May 2007
    pano po i flush yung ATF pra mapalitan ng PSF? or oks lang i mix nlang sila?
Power Steering
