Results 131 to 140 of 187
- Jul 2011
- 41
January 5th, 2012 12:46 PM #131mga gurus,, ask ko ano maganda ipalit sa shocks ng nissan eagle ko for more comfort ride, ok naman ang ride sa akin but i want to maximize the comfort na pede ibigay ng pick up, tnx
January 5th, 2012 01:50 PM #132
- Jul 2011
- 41
January 7th, 2012 07:27 AM #133* sir vinj, tnx sir, will do once may oras po ako, sa talyer kaya naman siguro nila, family ko lang naman sinasakay ko sa pick up, many thanks
January 9th, 2012 10:36 AM #134
Yup, kaya yan ng talyer. I did that with my Frontier before (Wheelers Suspension Haus did the work) since my family also found the ride to be harsh. If the ride is still a bit unharnessed after that, then you can look at options of upgrading to shocks such as Old Man Emu or Iron Man. The KYB Gas-a-Justs are nice and cheap but it wont help tame the ride too much as these are still firm shocks; it will help control the bouncy ride more though.
August 2nd, 2015 10:44 PM #135
* Banawe Auto Supplpy, magkano na ngayon ang KYB Gas-A-Just for Toyota T.U.V. front?
September 1st, 2015 08:16 AM #136
Buhayin po natin uli itong thread tsikoters, naghahanap din kasi ako ng shock para sa suv ko na pag dumaan lang sa onting lubak ramdam na at maingay.
- Apr 2009
- 551
September 5th, 2015 08:48 PM #137hi nakabili ako ng KYB shocks for my crosswind. yung box niya white background and green yung sulat pati yung shocks
colored green. may nakasulat naman ng made in japan. wala lang nakasulat kung gas siya or fluid. sabi ng auto supply
original daw na fluid shocks. original ba ito? tiningnan ko sa website ng kyb wala akong makitang kulay green na kyb shocks.
thanks
thanks
- Jul 2007
- 4
February 15th, 2016 08:10 AM #138Mga boss tanong lang po. Bakit parang ang tigas ng front suspension ko mga sir? Rinig na rinig po ang road noise sa loob sir. Huling pinalitan ko po yung shock absorber front ng KYB gas. Halos di po naglalaro mga shock kahit pwersahin ng bigat ko mga boss. " 250 lbs. po ako eheheheh". Coil Spring po kaya problema nito or balik ko nlng sa oem front shock ng mitsubishi? Help po grabe ang tagtag sa loob. Nag palit din po pala ako ng gulong na Delium. TY sa mga sasagot. 2011 MS
February 15th, 2016 05:21 PM #139
^hindi naglalaro KYB shock mo paps check mo baka may nakapasak na goma sa shock na pampataas. Sa akin matagtag dati may nakapasok palang bilog na goma sa tubo nya antanga ng nagkabit
- Jul 2007
- 4
February 16th, 2016 01:30 AM #140
^ serpentine belt Pala nagpapa-work Ng water pump sa k20 engine. Salamat Naman at ayuz pa...
waterpump area may konting leak
