Results 1 to 13 of 13
    My wife told me it happened to her 2 times already. Yung una eh kahapon habang lumiliko, tumigas daw yung manibela, ginawa nya reverse sya ulit para bumalik yung manibela then gas it, ok na. Then today while making a u-turn, after the u-turn at nag gas na sya ulit ok na.
    Can this be related to the battery? The car has been having problem starting since Monday, the battery is a 2 years old motolite gold, nag jump start lang kami to start it in Monday morning. Ever since medyo matagal sya mag start, one click pa rin pero it takes time to start. We are planning to change the battery tomorrow and hoping the steering problem will go away too.
    Should I have anything else checked?
    What car? EPS?
    What car? EPS?
    Vios 2nd gen.
    Vios 2nd gen.
    Before you replace the batt, check its health & charging system. If its the latter, don't grab the hobo reps.
    is your power steering still hydraulic?
    if so, it could be the PS pump.
    Jan 2008
    Its a vios 2nd gen.. its equipped with EPS na.. may be the EPS module lost its calibration due to the jump starting and low battery.
    Check alternator and battery health
    what year did the gen 2 vios start?
    aficionadoes may understand,
    but commoners still identify them by calendar year.
    Apr 2010
    if there is EPS orPower Steering warning, have the dealer check your car
    Yes. I believed it's because of your battery. Palitan mo na agad.
    Thanks guys. Just got my battery replaced with amaron ns60. The old battery daw eh OK pa charging but he said something na 80% na lang daw. So far OK na yung start. Hindi pa experience ulit yung steering problem. Sabi nga ng Minerva sa battery yung problem sa steering wheel.
    i thought,
    with the engine running, the alternator provides most of the car's electrical needs, not the battery.
    Just monitor the charging system, a known Vios weakness..the symptoms mentioned can happen when the alternator is on its way out. I hope it was really just the batt, though.
    Thanks for the tip.
Steering problem
