Got my kumho solus kh17 in less than a month... experience a road pot hole last wednesday, and i noticed a swell (bukol) on side wall so i have it checked by the tire shop where i bought it, sad to say they did not gave me my warranty for that deffect... Ok i understand that it is due to the bump from the pot hole BUT for LESS THAN A MONTH?! where's the quality and durability there?!I've been through much harder bumps with my old Good Year tires and havent experienced swell! Now i have to buy for another tire... i should have got a micheline tire!![]()
Potholes don't care how new your tire is.
That said, never go for the OEM spec Kumhos like the Solus. The sidewalls are way too soft. Go for the "sporty" ones, as those are more durable. We have two sets, the APTs (for our Crosswind... these are Dueler H/T equivalent, only they brake better) and STXs (Advan ST equivalent) on our CR-V. Only complaint is the road noise on the CR-V, but that's acceptable on a sporty tire like this. Been using both sets for around 40,000 kilometers worth, already. (and about 60,000 plus on the APTs) No damage, even with potholes.
i'm looking for a tire. mukhang mag kumho ecsta na ko. i'm thinking kung yokohama a drive or ecsta kasi readily available sa amin(bacoor) yung a drive. ecsta kelangan ko pa pumunta ng evangelista.
We got the Kumho Solus for our daily driver Sentra (185/65/R14) for 2.2K a piece. Yes the sidewalls are noticeably softer then the Bridgestone Turanzas and Goodyear Assurance we have on other cars the but so far so good... pwede na for the price and for running about the city.
magpapalit na ako ng tires since may crack on all 3 tires yung 205/45/R17 Nankang NS-2s nung Vios.all cracks starts from the sidewall to the corner of the tire. this was the tire recommended by VCP members back then nung maguupgrade ako ng rims. should have bought yokohama tires same spec sa XX limited/vios S.
. oh well, at least 3.1k per tire lang kuha ko nun and travelled 50Tkms which is almost the same distance travelled by stock yokohama 15's tires bago napudpod.
i'm eyeing for kumho Ecsta SPT or yung stock yokohama's used sa XX limited ng vios.
which is better buy? ayoko ng magkamali eh.hehe.
also, how much ba Ecsta SPT 205/45 R17? SRP from distributor (tiara) is around 6.3k eh. i believe mas mura pa yan diba?
thanks!
Sounds right... last time I got a quote for 16" SPTs, mga 4.5k. You might be able to get lower, but I doubt it'll go under 5.5-6k.
I don't like the Yokohama dBs on the XX Vios. In plain terms... they suck hideously. They're quiet, but grip isn't that great and the way they lose traction is kind of scary. Quiet, quiet, quiet... lurch.
SPTs will roll a little bit before you get to the edge of traction, and are much more predictable.
thanks sir. mga magkano ba yung 17 dBs ng XX vios? I agree dBs are quiet. one thing I immediately noticed nung palit mags with nankang tires. Ok naman kaya sila sa sidewall?Sounds right... last time I got a quote for 16" SPTs, mga 4.5k. You might be able to get lower, but I doubt it'll go under 5.5-6k.
Read more: http://tsikot.com/forums/newreply.ph...#ixzz1eb1rTOFZ
aw kumho takot nako dyan nasabugan ako sa likod last 3years dalawa sabay 5months old ang kia ko ayun binenta kona dahil rumolyo sa exway
