Results 11 to 20 of 22
- Dec 2010
- 8
December 20th, 2010 02:17 PM #11try nyo sa cruven..i am a regular client nila...so far ayos nmn service nila skin...
December 20th, 2010 02:36 PM #12
did you check kung putol ang springs? Maybe that attributes to the bouncy ride. restore mo na lang ang OEM na suspension.
December 20th, 2010 04:41 PM #13try nyo sa cruven..i am a regular client nila...so far ayos nmn service nila skin...
thank you again sa replies....
December 20th, 2010 05:12 PM #14
- Dec 2010
- 8
December 20th, 2010 05:18 PM #15tama, dapat pacheck mu na car mo, para ndi na madagdagan pa ang gastos mo..tried and tested q na ang cruven, the best!!!
December 20th, 2010 05:21 PM #16
December 20th, 2010 05:32 PM #17
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format & grammar.
Read the RULES.
Ignorance is NOT an excuse.
Repeated offenses will lead to banning.[/SIZE]
December 20th, 2010 10:19 PM #18
Seems like a side to side movements of the front wheels during bumps you say..I suspect too much cut on the springs during the lowering process. Sometimes this happens, that even after mounting the springs to the strut and removing the spring compressors (or alambre) the mechanic used, the coils will be loose on their mounts.
With the front end at rest, try to insert your arms inside the fender well and grab the springs if you can. If you can move the coils even a bit, too much cut has been done enough to cause stability problems.
December 21st, 2010 10:32 AM #19
Noted po lahat ng mga suggestions nyo.
kahit less than 5k odo, pwedeng bumigay ang suspensions. it all depends on the driving at mga dinadaanan ng sasakyan. kahit nga paglabas palang ng casa brand new tapos na-pothole ka ng malaki habang tumatakbo ng mabilis, pwedeng mawala kaagad sa alignment auto mo.
By the way, alam nyo po ba kung ano mga possible na maging negative effects nito sa auto ko kung sakali tumagal pa to side to side movement ng car na hindi ma correct?
December 21st, 2010 11:13 AM #20
Premature tire wear, dangerous driving condition; you'll be used to that for sometime you may not notice the worsening state of suspension until something finally give way..on the road.
high idle RPM at engine start
