Results 1 to 10 of 22
December 17th, 2010 12:48 AM #1
recently bought a 2006 jazz. naka lowering springs sa harap and stock height sa rear. napapansin ko lang is everytime na napapadaan ko sa mga bumps sa kalsada eh nag sway ung oto sideways(not sure kung eto tamang term). usually naman ang takbo ko lang is 60-80 km/hr pero meron pa rin swaying. may mga katanungan lang po ko.
1) normal po ba ito sa naka lowering springs? 1st time to own a lowered car kaya di ko alam.
2) may problem kaya sa suspension ko?
3) kung may problem man sa suspension, ano po kaya mga possible na pwede ko pa check.
thank you in advance po sa mga mag rereply.
December 17th, 2010 01:26 AM #2
It's not normal for any car to behave like that, lowering springs or not. Definitely, the suspension has a problem and should be checked at once. Suspects are suspension bushings, bearings, joints, tie rod & rack ends, shock mounts.
- Nov 2009
- 456
December 17th, 2010 11:23 AM #3Also have a 4-wheel laser wheel alignment. My brother-in-law once bought a 2nd hand Corolla GLi. When I drove it, the rear wheels swayed when I applied the brakes even on a perfectly paved road. Turned out that the right rear wheel was mis-alligned. After undergoing a wheel alignment, the swaying was gone.
December 17th, 2010 07:10 PM #4
dami pala i pacheck. but will do un mga suggestions nyo mga sirs. mileage nung oto ng kinuha ko is 42k pa lang. di ba napaka aga naman masira ng mga pang ilalaim na parts nya kung sakali un nga culprit ng swaying? ano kaya possible cause ng early damage sa suspension?
i had a 2000 city type z before. inabot ng mga 150k mileage bago ko nag paayos ng pang ilalim. all stock nga lang cya. Alam ko na drive na to(jazz 06) sa subic track day once, pero i doubt kung un naging cause ng sira sa suspension.
many thanks..
December 17th, 2010 08:18 PM #5
Ganun talaga eh. There really is no sure way to guarantee the useful lifetime of a part. Premature damage can be caused by a lot of factors such as the kinds of roads you drive on, the way you drive and besides, parts are known to be sometimes defective or badly manufactured from the start. They call it the Friday Batch; parts assemblers that were so eager to go home on a Friday they do a sloppy work on them.
Most of today's components are sealed-type, meaning you can not grease them during their service. Some innovative shops that repair suspension parts will put grease fitting on them for later maintenance.
The parts and repair cited here are just examples of what could be wrong and do not necessarily mean that all of them are.
December 18th, 2010 01:58 AM #6
thank you sir eric. napaka informative nung reply mo. nadagdagan un vocabulary ko dun sa "Friday Batch". hehe.
aniway, folllow up question lang po. un cruven ba kasama dun sa sinabi nyo na "innovative shops that repair suspension parts"? may nakita ko dito samin sa fairview kaso im not familiar with the company. i heard lang is that they repair worn out shocks. any feedback on them? thanks again!
December 18th, 2010 02:07 AM #7
ok naman sila. they have a branch here in makati and we use them sometimes lalo pag nagtitipid customers namin. Minsan, pinapadala nila customers nila dito for alignment after their repair.They repair suspension parts and even fabricate bushings and supports. Pero syempre, all will boil down to diagnosis. Kahit maganda repair nila sa ball joint eh kung di naman dun nanggagaling ang ingay, useless din.
December 19th, 2010 10:17 AM #8
pinagawa ko sa servitek un oto kahapon. pina allign ko na muna since kapapalit ko rin ng rims. according sa mechanic, naka toe out un front wheels. binanggit ko un swaying sa road bumps, sabi nya obserbahan ko muna after ng allignment. drove the car from fairview to roxas blvd, laki ng improvement pero meron pa rin konting swaying. no problem naman sa cornering, pero pag nadaaan talaga sa bumps kahit nasa straight line ramdam ung sway. buti ngayon nabawasan. pacheck ko n lang ulit cguro sa kanila suspension.
December 19th, 2010 12:56 PM #10
hindi naman po sir ghosthunter. konti lang binaba ng harap from stock, parang pumarehas ung fender gap nya tulad sa rear.
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
