Hi! Just acquired a used car a couple of months ago (my first). Ok naman xa then but recently I noticed prang tumabingi. Sabi sa shop my tagas shocks and malambot na spring so I had all 4 coil springs and rear shocks changed but still passenger side is about 2cm+ lower or closer to the ground. What could be wrong with it?
It's actually '97 lancer. Ah so ganun pla talaga pag lancer.. one suggested nga to add shims under the right springs e kso it would reduce naman working range of the springs so I thought something else must be wrong kung bago naman lahat ng springs ko. Sumasabit parin kasi ung likod.
Kind of strange that it's the passenger side that's lower; usually it's the driver's side that's lower because that has the weight of the driver on it more often.
Should be okay, but if you're alarmed rubber or aluminum lifters would do the job. Better aluminum for me personally because there's no springing effect from the material, unlike rubber.
