Results 11 to 13 of 13
January 6th, 2012 11:25 AM #11
If the rim is not cracked or the chip is not deep, then it's fine. The bead of the tire is well inside the lip.
40 psi is fine. It will feel very stiff, depending on your tires, but it's fine. With such wide tires, though, you might find the steering twitching and following ruts much more at those pressures.
- Jul 2008
- 935
January 6th, 2012 10:56 PM #12
- Jul 2011
- 262
November 13th, 2012 03:03 PM #13ups ko lang po uli,,gusto ko gawin ito sa aking pregio..masyado ng mababa kapag full load..TIA
high idle RPM at engine start
