Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Oct 2015
    My car is a Toyota Altis 2009 model. Since yesterday napansin ko na nakailaw pareho and ABS and parking brakes (kahit naka baba na hand brake ) habang umaandar ang car. Dinala ko sa mekaniko ( hindi sa casa) at nilagyan brake fluid kasi kulang na. Nawala naman ung warning lights nung paalis na ako. But after around 10 minutes ko na naitatakob pauwi, umilaw ulit pareho ABS and parking brakes warning . Ano po kaya problem kung ganun?
    Pa advise naman po.
    Sep 2012
    Quote Originally Posted by BerrySnow View Post
    Pa advise naman po.
    Check mo ulit level ng brake fluid mo... kapag nabawasan, it means may leak
    Sent from my ASUS ZenFone 4 using Tapatalk
    Oct 2015
    Quote Originally Posted by jodski View Post
    Thanks, pero mukhang di naman nabawasan. Kanina ganun ulit, mga after 10 minutes na tumatakbo tapos umilaw pareho ABS and paking light. Baka daw grounded sabi ng mekaniko. Kailangan ko maghanap ng car electrician, tama kaya advise?
    Nov 2017
    Ang kailangan mo ay yung nagre reset ng OBD..to cancel the abs light, much better if early, pag nagtagal ay di na kaya alisin.
    Aug 2013
    Pa advise naman po.
    ipa check mo wheel bearing, ganyan nangyari sa vios namin bro.
    Oct 2015
    Quote Originally Posted by noelbanat23 View Post
    Thanks po sa reply.
    So , kung ipapareset lang, that means walang other problem?
    Quote Originally Posted by innova2013 View Post
    Thanks , will have it checked.
    Feb 2012
    Not saying na tama, but you may try to seek an automotive electrician first. Yung 2003 ko kasi naging ganyan din dati. Pero more on the ABS light lang. Ang nangyayari naman sa akin tuwing bubuksan ko ang ilaw, whether headlights or park lights, eh umiilaw ang ABS light after about half a minute. So for a long time I just ignored it na lang since mukhang everything is working fine naman. Only until napansin ko na wala na rin pala akong park lights at brake light. Yung brake light eh busted na, pero yung park lights looks okay pa naman.Tried my best to diagnose and correct the situation to no avail. Nung dinala ko sa electrician, inayos lang contacts ng park lights at nag-okay na lahat.
    Oct 2015
    Quote Originally Posted by gearhead000 View Post
    Thanks ! Will have it checked by the car elect.
    Jul 2006
    Check your brake pads, they may be due for replacement.
    pa scan mo ho abs mo, meron fault yan kaya naka olaw abs and parking brake. hindi pwede I reset yan yyan, you need to repair the cause of the problem
Help! Warning Lights for ABS and Parking Brakes
