Results 11 to 15 of 15
February 12th, 2007 10:32 AM #11
Share ko lang ang final solution sa leak ng PS pump ko. After two repair kits, wala pa rin. May leak pa rin. Finally, nagpalit kami ng Shaft and oil seal. Problem solved. Thru time lumiliit ang diameter ng shaft at nagkakaroon siya ng mga grooves. Doon dumadan ang leak. Sa Isuzu 4ja1 na PS pump, ang shaft costs P2,400 (orig). Oil seal P300.
August 14th, 2007 09:49 PM #12
sa akin nakuha naman nun cyclo power steering stop leak after ko nagpalit ng main hose ng bigbody gli. nawala na todo yun konting tagas.
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Aug 2010
- 2
September 8th, 2010 11:42 AM #14
- Aug 2009
- 9
October 14th, 2010 01:33 AM #15pahabol din ako medyo may leak yung PS ng GLI ko 95 model...
sabi sakin na di na daw ganun tatagal at di ako mabibigyan ng warranty kapag repair kit lang ang option ko ay
1. toyo brand PW repair kit cost 6500 kasama labor at electro plating ng shaft
2. Original toyota repair kit PW 9500 kasama labor at electro plating ng shaft
3. Recondition na rack and pinion 15k
advice nya ako na option 3 ang gawin ko kz lagi daw sila talaga nag papalit ng kit lang at kapag talagang may tama na back job lagi...
may wiggle ng konti yung gulong and leak yung PW ko diko alam kung sira na un...
ROBUST
along shaw ko pala ipapagawa d'best
high idle RPM at engine start
