Originally Posted by
niky
DOT5 is not always recommended for street use, as it can eat into things... can your system actually take DOT5 without damage? You should read the warnings on the bottle first... DOT4 is the most aggressive fluid you will need for road use.
Slotted rotors aren't that expensive. Stock size should be between 5000 to 7000 pesos for a pair of front discs for your vehicle. That's not much more than brand new replacement discs. It's big brakes that cost a lot.
But if you want better braking, go stainless lines (will cost about as much), get better pads, and, most importantly, check that your discs are flat. have them refaced if they're warped, as warpage can cause poor brake feel and a deep pedal. But be warned... discs can only be refaced so far. if refacing doesn't do enough, then it might be time to replace the discs.
