Results 1 to 13 of 13
    Oct 2004
    feasible ba ito guys? yung rear drum brake kasi ng everest ko plan ko convert into disc brakes. Madali kasi ma stuck up yung drum brake lalu na when driving in deep flood waters. Mahirap maiwasan kasi area namin always flooded. yung crv ko with all wheel disc brakes never pako naka encounter na naninikit ang brakes. How much kaya aabutin ang ganitong project?
    Aug 2005
    Quote Originally Posted by bratski View Post
    possible yan.. pero gagastos ka din..
    sa surplus shop mayroon ata silang disc brakes..
    tanong ka din kung gagana pa din yong hand brake mo if pinalitan mo ng disc brake..
    Jul 2006
    Also make sure yung disc brakes na i-retrofit mo is a direct bolt on. Wala nang retoke, wala na customization dahil usually doon nagsisimula ang disgrasya oras na bumigay. Critical point ito ng safety ng sasakyan mo kaya di ito tinitipid. All I'm saying is kung gusto mo talaga ito, lubusin mo na lahat kaysa sa gawin mo pero so-so lang pagkagawa.
    If possible tanungin mo yung casa ng Ford kung meron silang direct replacement for it. Kasi ang isa pang problema dyan is kung yung drum brake is integrated sa suspension ng Everest, baka kailangan din palitan yung suspension components --> mahal!
    not worth the pain; you've got to replace also the master cyl, proportioning valve, etc...
    Oct 2004
    Quote Originally Posted by t2erns View Post
    Hmm..malaki pala gagawin pag pinalitan, sabi ng mechanic ko direct swap lang daw
    hindi ata kelangan magpalit ng suspension components pero tingin ko handbrake magkakaproblema. Ang everest ba sa propeller ang handbrake or mismo dun sa loob ng drums?may mga iba kasi na sa propeller kumakapit ang handbrake.
    Wala naman ako balak tipirin kasi safety din habol ko. Kaso kung matrabaho sobra like palit ng master cyl etc etc parang hindi ata worth it
    My sentiments exactly.
    If you're worried about your brakes being affected by wading though floods, it's easier to open up the drums and clean them from time to time and to change brake fluids regularly.
    Dec 2003
    Sabi din longer brake distance kapag nagdisc brake ka sa likod ah..
help:Drum brake to disc brake
