Results 41 to 48 of 48
- Feb 2008
- 577
March 2nd, 2008 10:46 AM #41
March 2nd, 2008 11:58 AM #42
sir spy ghost, your in luck. dumating dito mekaniko ng dad ko from pasay, atco yung name ng shop. directions --> if your coming from edsa, take the pasay flyover then straight lang until you reach the lrt. make a right turn, around 50 to 100 meters and your there na. its to your right... atco has genuine parts for mitsu. sabi din ni don don (mechanic) na if palit ng shocks baka kailangan din ng palitan yung rubber na nandun. i just have no idea kung anong rubber yun.
btw, don don fixed our accord pero they have people that do mitsu but if you have a mechanic na trusted... just buy the shocks there and let another shop take car of it.
- Feb 2008
- 577
March 3rd, 2008 08:33 AM #43
March 3rd, 2008 03:02 PM #44
for the fluid type... i ask my cousin on what they use sa pizza nila, sabi yung kyb na gas kasi wala na daw sila makita na fluid... puro gas na daw replacement. im not sure though kung saan sila nagcanvas.
the ride daw is much stiffer than the OEM. wala daw pera kaya yun na lang muna until masira. im sure atco can give you what your looking for sa ride tsikot niyo. im sure they have OEM types pa dun and the prices naman are reasonable. if you have busted shocks na, id advise na wag niyo muna gamitin as a daily driver kasi mawawala naman yung integrity ng springs niyo... sayang double gastos pa.
- Feb 2008
- 577
March 3rd, 2008 07:59 PM #45sige boss, pasuyo naman hehe... para makabili narin ako. actually pati coil springs palitin narin. most probably pati mga shock mounts
- 1
March 3rd, 2008 08:07 PM #46Hi all,
This is my first post here. I would share some great flower sites with you.
#1 http://www.automotive.com/
#2 http://www.usedcartrader.co.uk/
#3 http://www.used-car-dealers.org/
#4 http://www.getauto.com/
#5 http://www.cars.com/
Hope to contribute to this board more often later. Thanks
Cheers
Gilchrist Adam
- Apr 2008
- 84
August 13th, 2008 01:40 PM #47boss, what if naka lowering springs? gas type na ba agad dapat dun instead of fluid type? wala pa nagcoconfirm dito sa forum na yun ang best match eh. i want to know if best practice na lowering springs should always go with gas type shocks.....clarify lang po.....
thanks
Tsikot Member Rank 5
- Nov 2003
- 3,849
August 17th, 2008 04:26 PM #48lowering springs = higher spring rate = matigas
gas shocks = higher internal damping = matigas
matigas + matigas = mas bagay na ride.
hard springs and soft shocks are not the way to go.
