Results 21 to 26 of 26
- Feb 2013
- 910
October 13th, 2021 12:38 PM #21
- Jan 2008
- 4,726
October 13th, 2021 01:14 PM #22thickness po sa brake pad.. pag di na kita yung guhit sa gitna, replace..
- Feb 2014
- 2,536
October 13th, 2021 01:27 PM #23so after 16yrs of changing brake fluid every 3yrs i finally got some corrosion pitting inside my rear wheel cylinder, which resulted in a slow-ish leak. that's good enough i guess every 2yrs is going to be even better
October 13th, 2021 01:47 PM #24
October 13th, 2021 09:04 PM #25
Glycol based brake fluids (all except DOT 5) are completely miscible with water. Even with the limited movement of fluid from the master to the slave cylinders they should mix freely and completely.
- 52,701
October 13th, 2021 09:56 PM #26
