Originally Posted by
jick.cejoco
anthon,
if you could give me the following readings, it would be greatlly appreciated:
caster- left and right
camber-left and right
toe
toe out on turns (TOOT)
steering axis inclination-left and right
front wheel set back
wheel base right
wheel base left
thrust angle
front wheel bearing preload- left and right
assuming all tires are of the same diameter, tread pattern between left and right, tire pressure readings as per specs, then a pinpoint accuracy diagnosis and recommendation is on the way
jick
