Results 1 to 10 of 30
- Apr 2009
- 536
June 29th, 2009 01:01 PM #1Hi tsikoters...
need your advice.. yung front right side wheel ng crosswind ko, d pantay kain ng goma. yung outer niya mas pudpod compared sa inner. pero slight lang been using the wheel for more than a year.
advice sa akin ng iba pabayaan lang daw ganun tlaga sa front. yung iba naman advice sa akin pa wheel allignment.
Ano sa tingin niyo? totoo ba kung pinaayos ko sandali lang balik na naman sa dati kasi malulubak din naman.
thanks
June 29th, 2009 01:03 PM #2
alignment yan bro. pa check mo na lang din. mahal ang goma. most probably excess toe yung harapan mo.
June 29th, 2009 01:05 PM #3
and imho, hindi sa lubak yan... may worn out suspension components ka that causes that excessive toe... most probably, tingin ko dyan is yung tie rod or ball joint. pero mas maganda kung mapa check mo dahil mas mahal ang goma, specially dyan sa xwind mo.
June 29th, 2009 01:27 PM #4
June 29th, 2009 01:43 PM #5
pag alignment ang problem, after the fact mo na kita ang result. Hindi pantay na pudpud ng gulong.
- Feb 2009
- 36
June 30th, 2009 04:38 AM #6question:
what's the ideal number of months / kms of having your alignment/camber checked?
every 6 months? every x,xxxx km?
June 30th, 2009 10:24 AM #7
- Jul 2003
- 573
July 3rd, 2009 08:05 PM #8kung front right side lang kamo ang mas pudpod at labas, masama ang adjustment ng toe, caster at camber. makikita naman yan sa electronic wheel alignment checkup.
- Apr 2009
- 536
July 6th, 2009 07:09 PM #9Hi ... thanks to all.
I will have it checked. in the meantime pinalipat ko lang gulong, i mean yung labas na pudpod pinalipat ko sa inner.
my crosswind's mileage is 100k.
July 11th, 2009 03:03 PM #10
anthon,
your right tire wears out on the outer side normally if you drive on the right side of the road as in the u.s., australia and the rest of the world except england and japan. it is simple geometry, you take a bigger radius turning left than turning right. when you turn left, specially you make it quicker since the traffic lights in the Peelipins are crazy, when you turn right, the radius is tighter and you don't really see 100% what's around the corner, you tend to turn slower. hence your right front (wheel #2) outer side of your tire tends to wear out faster. have your tire rotated as per owner's manual, or every 20k miles.
jick
There is no spare tire to reduce weight and increase fuel efficiency ... for marketing and...
2025 Nissan Kicks
