Results 1 to 20 of 25
    Dec 2010
    i have a ford fiesta... 2.5k km odo.
    if the steering wheel is straight... may konting kabig to the left. to go straight... the steering should be about 3-4 degrees to the right.
    alignment problem ba to? baka nalubak.
    tire pressure is ok. didnt modify anything. stock mags/tires and all. di daw kasama sa warranty alignment and theres a 900 consultation fee (?) sa casa. so im thinking of bringing it sa goodyear servitek.
    any ideas?
    Quote Originally Posted by antikryst View Post
    any ideas?
    Wheel alignment nga yan IMO sir. Servitek na nga lang. Pero ang bulis naman niyang nag-mis aligned. Yung Avanza ko dati at advie, parang 3 years bago nagpa-align.
    Dec 2010
    feeling ko nalubak. the car i replaced parang once every 5 years lang pa align. it was a lancer glxi... 18 years before i replaced it haha.
    Ganyan din yung jazz ko. Nung bago pa lang yun pag diretso ang manibela pumupunta sa kaliwa. wala akong alam sa oto non kaya hinayaan ko na lang. pwede mo ibalik siguro sa casa yan sa PMS mo.
    Feb 2009
    the problem is in the clocking of the steering wheel. the steering angles might be correct but the over the center adjustment is off. but then again it is a ford. have the tie rods adjusted to the 12'oclock steering wheel while the front tires are straight ahead. this should be taken care of by the dealership and it usually takes less than 20 minutes to reclock the steering wheel
    Jul 2010
    Alignment lang yan bro, sana walang bayad.
    Dec 2010
    do you think its more of a clocking than alignment? kasi if its clocking i can live with it for now. just worried ill ruin my semi new tires this early due to alignment problems.
    kung clocking lang i can wait for my next PMS (6 months) which is about 3 months away.
    is there a way to check if its just clocking or alignment?
    Apr 2011
    any ideas?
    I don't think alignment yan sir. Mashado maaga for it. Try rotating the wheels. :D pag palitin mo lang yung left and right front tyre. pag may kabig pa rin, try rotating the rear and front tyres.
    May 2011
    Any update on this Boss? My cousin's fiesta is experiencing the same issue. He asked me to test it and I have to constantly hold on the steering while driving kasi may slight "kabig" on the left... Di kaya factory defect siya?
    Apr 2011
    ts...free lang yan sa dealership mo for alignment..ibalik mo na agad yan at para mapa ayos na baka un iba pa ang masira like suspension and alike.
    Jul 2003
    subukan mo i-drive sa gitna ng kalsada o kaya sa opposite lane kung ganuon pa din ang kabig. normally kasi yung kalsada natin eh may grade.
    Hindi ba covered ng warranty yan? Alignment sa Servitek I think is 1.3K, f/r na yun.
    any ideas?
    Mga Sirs,
    Nabili po ako ng Used Adventure model 20007. Hinde ko na nakita na merong misalignment-ng dinala ko po para matingnan sabi sakin sa gas service center na sagad na raw ang adjustment - sabi po ng mekaniko kailangan na raw dalhin sa machine shop kaya lang nag aalangan ako kasi baka maapektuhan ang strength ng kinakabitan - ok lang po ba pa machine shop para maayos ang alignment? ano po ba ang bad effects sa ibang parts ng sasakyan pag na machine shop- thanks po- una ko po kasing sasakyan ito at wala akong alam sa pag kalikot nito
alignment problem on new car
