Results 1 to 6 of 6
    Aug 2005
    HI mga sir.. Gud pm..
    tanong ko lang kung kailan dapat mag pa cleaning ng drum brakes at palitan yung brake shoe..
    if not well maintained what could be the possible damage?
    -Finchy
    Brembo Brembo Brembo
    Sep 2005
    sir,
    all types of brakes whether brake or disc should be cleaned every 5th km. sabay mo sa oil change and tune up. replacement usually visual inspection pwede na at dapat palitan kung mga 25% na lang ng original thickness.
    same with disc brakes, if the shoe is worn out, it will damage the brake drum. rotor disc for disc brakes.
    sayang pera pa reface. worse yet, replace.
    Aug 2005
    how much kaya brake shoe sa corolla?
    Nov 2003
    replacements might be less than 1k or somewhere in that range.
    I usually clean my drums (DIY) with brake cleaner every 10,000kms.
    The rear drums don't wear out as fast as the front ones also.
Drum Brakes (maintenance)
