Results 1 to 3 of 3
December 21st, 2007 03:42 AM #1
mga sir paano po mag drain(flush) ng PS fluid para mapalitan ko yung madumi ng lumang fluid? medyo mabigat na kasi manibela. TY
December 21st, 2007 10:43 AM #2
Check your PS reservoir, 2 hoses for inlet and outlet. use any suitable container/plastic para saluhin lahat ng PS fluid, tanggalin ang inlet hose and drain ang reservoir, and lagyan din ng container ang inlet hose but make sure secured ito kasi bubuga ito ng fluid at magkakalat sa engine bay, pag fully secured na ang plastic sa inlet hose. paandarin ang makina ang then turn max left/right, pagwala nang lumalabas sa inlet hose na PS fluid try to put a bottle of ps fluid sa reservoir and then operate uli for flushing of remaining old PS fluid, then reconnect inlet hose sa reservoir, add new PS fluid sa reservoir, run the engine and turn again max left/right several times to bleed the system of air. check for leak ang fluid level.
December 21st, 2007 01:21 PM #3
sir thanks sa reply.. yung inlet hose ba yung tube sa gitna ng reservior?
high idle RPM at engine start
