Results 1 to 10 of 11
February 21st, 2007 06:50 PM #1
try mo yokohama geolander, imo eto pinaka macho na a/t tires
pros
Well, they're good on mud and extreme offroad use
cons
poor braking performance especially on wet surface
wears out easily on tarmac,
noisy? well not that much, unless when the tread reaches 50 % or less.
February 21st, 2007 08:07 PM #2
dati we installed mickey thompson tires m/t on our pajero gen 2.5. maingay sha when it reached 80 kp/h parang mas nagiging maalog. ambilis pang napudpod. guapo nga tingnan. pero meron naman yata mga M/T types na pwedeng pang araw araw.
February 21st, 2007 10:47 PM #3
I'm using bridgestone MTs for my daily drive mag 3 yrs na this Nov '07. Yun Dunlops na AT ko dati lampas one year lang bagsak na sa standard ko...hehehe. There are soft compound tires which offers better ride as against hard compound but suffers in the wear category.
February 22nd, 2007 01:02 AM #4
Other than noise M/T tires wear faster if used mostly for street. A/T tires would be better if you use it for mostly street and want it to look good. But there are also differences in A/T tires, some more bias towards road use and others off road.
Here's a list of some A/T tires with the top of the list being more street bias and the bottom being off road. I think any of the last four on the list would fit the look that you want in a tire. BTW I use the BF Goodrich tire and have gotten complements on the look of it on my truck. Check this site if you want to see what each look like.
http://www.discounttire.com/dtcs/fin...4587&rc=CEBINT
Pirelli Scorpion AT
Michelin LTX AT
Good Year Wrangler Silent Armor
Kumho Venture AT KL78
Cooper Tires Discoverer ATR
Pirelli Scorpion ATR
Bridgestone Dueler AT 694 Revo
Yokohama Geolander AT+II
General Grabber AT2
BF Goodrich All Terrain TA/ko
February 22nd, 2007 09:24 AM #5
i'm using Maxxis Buckshot Mudder. how about sa fuel consumption? meron po bang negative impact ang mga M/T tires?
February 22nd, 2007 10:08 AM #6
tsong i suggest you get the pirelli scorpion, gamit ng tito ko yun sa frontier nya, it lasted 4 years bago siya nagpalit ng panibagong pirellis, pantay pantay ang pagkaubos and for me i never felt any discomfort while riding in on it actually nabawasan pa nga yung parang yanig ng mga passengers pag nadadaan sa mga lubak at humps, anyhow basta imaintain mo lang mga pang ilalim ng tsikot mo and the same thing would happen to you
- Apr 2006
- 288
February 22nd, 2007 10:26 AM #7Mga sir: What would be your choice between Bridgestone Dueler AT and Pirelli
Scorpion AT for a 2.5 gen pajero? Thanks in advance.
February 22nd, 2007 10:39 AM #8
Hi All!
ravelcop:
I currently have the BF Goodrich All Terrain T/A KO on my rig and it's OK.
If you really want an M/T, I hear that the Cooper Tire Discoverer SST with Armortek is really good if you don't want a really hardcore tire.
I hear it's really good on pavement and it's supposed to do well off-road as well.
If ever, I may get these when the time to replace my BFGs come.
Hope this helps.
:regards:
February 22nd, 2007 10:59 AM #9
Off road tires larger than the OEM will affect the fuel consumption and it is going to be higher. M/T's wear faster and most don't handle very well on the street much less a wet road. Keep in mind they are called mud terrains for a reason, they work better on loose soft dirt and muddy terrain. The tread patterns are made to grab dirt/mud with big and wide threads and soft compound rubber. This also means when it's on a hard surface such as the street it will flex and you don't have as much rubber meeting the road. Additionally the same design that grabs the mud also doesn't encourage water evacuation on wet roads. If you want a meaner looking off road tire the best compromise for the street is a A/T. I know of guys using the BF Goodrich AT/ko that used them until 75K miles or 120K Km on the tire and that's with some serious rock crawling.
Thread was made nung 2018 pa po sir.
