Results 1 to 6 of 6
- Nov 2011
- 79
January 15th, 2012 10:29 PM #1i have a stock rim and my tires are worn-out already. Is it possible to replace a different kind of tire specifically a wide one? :stone:
- Jul 2011
- 447
January 16th, 2012 10:27 AM #2
January 16th, 2012 11:02 AM #3
pwede yan. pero certain width nga lang. let say yun tire mo 195x55x15 pwede ka mag wider tire to 205x50x15. Pwede pa nga mga smaller width tire on wider rims, tire stretch setup ganito:
F1 style tire.
But its best to stick to manufactures specs. Expect, madami mabago drivability, tire wear, noise, fitment baka sumayad na yan sa mga pangilalim, pag wla ka sa specs recommended for the rims.
Pros nito? Better grip on cornering and braking, if you're racing. kung daily lang... wala! sayang lang pera mo, stick to whats recommended.
January 16th, 2012 11:48 AM #4
Good luck actually finding a low profile tire narrow enough to actually "stretch" over a stock rim.
How wide you can go depends on how wide your stock rim is. Most stock wheels are 6" wide. The widest tire that will look right on that rim size will be 195 to 205mm wide. But the wheel will take up to 215mm. Not quite sure about 225mm.
But if you want more performance, your 195 or 205mm tires will actually be wider if mounted on a 6.5" or even 7" wide rim.
- Nov 2011
- 79
January 17th, 2012 09:47 PM #5Actually i have a 15" rim and 205/70 r15 bridgestone tire. What would be the maximum inches of the width to fit into that kind of rim. The rim is a crv 1st gen 15" stock rim.
January 18th, 2012 12:10 PM #6
If it's for comfort, you can simply go for a more upmarket tire.
If it's for performance, better to upgrade your rims and tires. The closest to your tire size I can find is 235/60R15, and that's a very unusual size, and will be very hard to find. If you go for a wider tire that's also taller (the wider a tire gets for the same profile, the taller it gets), that will negatively affect the fuel economy and comfort of your vehicle.
Daming issue ng SU7:grin:
Xiaomi E-Car
