Results 1 to 8 of 8
- Jul 2017
- 7
August 2nd, 2018 06:10 PM #1binaklas ko po yung cv joint (inner) may lumabas na oil parang putik na, puede bang gear oil ang replacement. thanks
August 2nd, 2018 06:45 PM #2
cv grease. inquire sa tgc auto parts...
August 2nd, 2018 06:45 PM #3
- Oct 2006
- 6,260
August 2nd, 2018 07:29 PM #4CV joint grease uses a lithium and molybdenum sulphide compound mixed in.
Sent from my P01MA using Tapatalk
August 2nd, 2018 08:07 PM #5
Outboard birfield joint grease and inboard plunge joint grease are sometimes of different formulation. But both are NLGI 1 viscosity (semi fluid). To avoid surprises, ascertain whether the grease is the correct or recommended type. If the grease is thicker, it can cause noise and the car consumes more fuel.
- Feb 2014
- 2,700
August 2nd, 2018 10:57 PM #6
well lithium is just a thickener. and i'm not even sure if CV joint grease uses a lithium thickener. but yes "moly" or molybdenum disulphide is an important component in a CV joint grease.
a CV joint probably won't last very long if you just use a plain grease like the 2 pictures above
Tsikot Member Rank 2
- Jan 2008
- 4,726
August 2nd, 2018 10:48 PM #7
August 3rd, 2018 01:48 AM #8
My mistake. It should contain moly indeed.
Wuerth has a specific cv joint grease pala.
Never had problems with top 1 but it is for cv of 4wd so its not used that often that is why it may have been okay after all this years. Different from passenger cars cv joints.
Sent from my LG-H990 using TapatalkFasten your seatbelt! Or else...Driven To Thrill!
Ford kasi... it needs a lot of TLC. ;) Kidding aside, I don't know if other turbo vehicles have...
0dometer problem
