Results 1 to 9 of 9
    May 2011
    help nmn po.. wat probably ung problem nung front disc break ng auto ko.. nissan ex saloon 1999..nakadikit kc ung disc break.. nagiinit ung disc break..thank you
    Feb 2009
    if your pads are so worn out and your caliper pistons stuck out beyond designed limits because of too thin brake rotors and too thin brake pads, they might not retract from caliper seal memory retention. the pistons too, if they are rusted because of torn dust boots will seize and not retract. remember, there is no return springs for the caliper pistons. the other possibility is that the brake hoses might have restriction. it might have residual pressure because of this constriction in the hose and it tends to build up heat and pressure thereby self applying the front brakes when you don't need it to.
    Feb 2009
    hehehehehehe. just re-reading, stuck up or stuck? i kinda noticed this "stuck up" phrase
    May 2011
    stuck lng pala.. hehe.. thnk you..
    Sep 2008
    brake not break
    May 2011
    ah ok thnk you po
    Quote Originally Posted by bistek11 View Post
    [SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
    Read the rules.
    Ignorance of the rules is not an excuse.
    Repeat offenses will lead to banning.
    [/SIZE]
    May 2011
    thank you po sa advice..bgong palit po ung break pads nung disc break..d nga po nmin mfugure out kung ano ang problma.. nilinis n dn nmin ung piston nya..ung hose n lng po check nmin.. thnk you po ulit
Stuck up front disc break?
