Results 11 to 20 of 37
March 14th, 2011 11:07 AM #12
Torsion bars are more a different form of spring wherein the torsion (twisting force) is used to dampen the suspension. Coils and leaves both work by compression.
March 15th, 2011 11:28 AM #14
SPRING TIME!!!
Just to add up to the discussions above.
A spring by definition is any type of material, when distorted, returns to its original shape. They are usually used in conjunction with shocks/dampers which control the suspension movement.
Functions of a spring
1. Support vehicle weight
2. maintain ride height
3. Keep the tires in positive contact with the road surface.
Basic Types of Spring
1. Leaf Spring
2. Coil Spring
3. Torsion Bars
4. Coilover (modified set-up)
Spring rate is the amount of force that is required to move a spring and measured in lb-in.
Load rate is the amount of weight the spring is designed to carry at ride height.
Now with regards to the pros and cons of those springs.
LEAF SPRINGS
Rugged, simple and oldest form of spring technology. A standard of auto suspension for decades but the role is slowly being reduced even in applications where it has been the stalwart (pickups).
These uses a series of steel plates of varying length (tapered) and thickness bound together to form a pack. Some uses monoleaf and multileaf. Number and thickness of leaves dictate spring rate and load capacity. Length effects ride quality and width handles stability.
Leaf springs are progressive-rate springs. They grow stiffer the more they are compressed which makes them superior for heavy loading.
They are also modular just like our LEGO toys. You can change ride height or capability by adding or removing leaves. Higher quality packs will use multiple, thinner leaves to reduce fiction and this makes them more durable . If one leaf snaps, other leaves will carry the load home.
There are also two stage spring packs. In addition to the progressive-pack, an overload leaf (horizontal) leaf is added to gain maximum load rating while retaining good ride characteristics when unladen.
Most importantly, leaf springs control and locate the axle without the use of control arms. But if the centerbolt breaks, the vehicle will dog-track. Imagine running the vehicle a little bit sideways.
Leaf springs are also more stable when loaded
In short, the pros are: they locate and control the axle, superior stability when loaded, simple and easier to lift.
Yet, the cons are: they are harder to tune for ride, heavy weight, take up a lot of space, susceptible to noise and prone to axlewrap (the leaf tends to make an "S" shape) especially on high loads under high torque and sudden acceleration.
March 15th, 2011 12:03 PM #15
COIL SPRINGS
A coil spring is a steel metal wire that has been wound into the shape of a helix to resist compression. Excellent ride characteristics and low noise. Compression coil springs are the most common type of auto springs.
Spring rate is determined by the thickness of wire and pitch of the winding. Basically we have two types, the linear-rate and variable-rate. For the linear spring, the pitch or distance between winding is the same and you would experience the same vertical travel rate as you go over bumps while the variable-rate somewhat acts like a progressive leaf spring. The pitch is different. The upper portion have wider spacing between the windings while it is closer at the bottom (wound up with with varying pitch) and acts like this: soft on the first then harder later.
Benefits of coils include compact size, ability to precisely tune the suspension and wheel travel. They do not also involve internal friction and weigh much less than leaf springs.
Yet, coil springs do not locate the axle and therefore require links to work. Those links add up to the cost and complexity of design but it is the main reason why coil-sprung suspensions are good at resisting axlewrap unlike in leaf springs.
The taller the coil, the more they are prone to deflection (bowing) which can diminish their effectiveness over time and causes interference to suspension neighbors. Additionally, they can weaken and sag over time and not as durable as leaf springs in heavy duty applications.
In short (again), the pros are: quiet, better ride, easier to tune, lighter weight, eliminate axlewrap, capable of big articulation BUT need links, can sag over time of if overloaded, more suscetipble to sway, expensive to retrofit, limited lift heights and not as robust as leaf springs.
TORSION BAR
Perhaps the least common of the springs but are still used (in my case, just like Isuzu Pickups/Fuegos) where the IFS uses torsion bars.
Torsion bar/spring is a long metal bar that is attached to a fixed mount on the chassis on one end and attached to a moving part of the suspension and is mounted perpendicular to the direction the torsion bar is mounted (ex. lower control arms).
As vehicle moves up and down, torsion bar twist on its axis, resisting the suspension movement and returning it to center. Thickness and length of the bar determines it strength, spring rate and load capacity.
They are known for their durability and ease of replacement and maintenance.
Changes in ride height are achieved through "twisting" or "cranking" of the bars by adjusting preload through the adjuster nut connected to the chassis. But this will limit downtravel diminishing ride quality. Other negative effects will come out if it goes beyond the generally accepted "safe" range of 1.5-2 inches (depends on the vehicle)
Drawbacks are a lack of progressive or variable rate option (less flexibility when loaded especially going over harsh terrain along with limited wheel travel.
Pros: durable, simple, easy to make minor adjustments in ride height
Cons: Spring rate not progressive, limited wheel travel, few aftermarket options.
COILOVERS
A spice girls moment when 2 become 1. Coil-over-shock absorbers set-up. Even more compact than coil sprngs, this includes a shock absorber and coil spring in one unit. Coil spring is mounted to the shock and not the car.
Greater heights are achieved without considerable coil deflection. Plus they are mounted in bearing preventing bind under articulation.
Changing spring rates is as easy as pulling the unit and swapping to a different coil. Threaded bodies allow preload and ride height to be easily changed while coilover is mounted on vehicle.
Biggest drawback is the expense as well as fabrication may be required to fit on a vehicle.
Take your pick. But just keep this in mind: "All springs are application-specific. There is no such thing like the universal spring." Parang t-shirt kumbaga na one size fits all.
- May 2011
- 153
May 28th, 2011 03:42 AM #16Question po (Sana di OT)...
Are all leaf-spring matagtag? The ride is a bit uncomfy for the rear passengers. Bago lang kasi yung sasakyan, I'm thinking if further usage of the vehicle will soften the ride or talagang ganun sya? If ever, what are the ways to make the ride a bit comfortable? (bawas leaf, palit shocks, etc).
Thanks.
May 28th, 2011 08:28 AM #17
No. Somehow Isuzu and the leaf spring of the CRDi Strada seems to be better than previous leaf springs that they have. Puwede bawas ng leaf spring or to retain the height pa din, I reco that you use shorter and cut leaf spring as spacers to replace a full leaf at each side for more comfy ride. Dagdag sa FC kasi yung 2 bags of sand trick and not advisable if ot a pick-up.
But don't do anything without knowing the results and taking into consideration how you use your ride.Fasten your seatbelt! Or else... Driven To Thrill!
May 31st, 2011 01:53 PM #18
Pansin ko din sa torsion bars you need to crank them periodically pag nagiging matagtag na yung ride. They become harsher with more kms of usage so you need to keep adjusting them every so often.
Re: suv/pickup rear suspensions I think what makes the Fort and other top heavy suvs roll more than the Alterra is the higher center of gravity vs the track and not necessarily the suspension. The reason they don't change anything in the design is probably because they can't justify the cost of changing the suspension vs the benefit of projected sales from those changes.
Having a longer wheelbase and wider track is better but saying a vehicle being heavier is an advantage is silly.
*Ry
Yung Dmax matagtag pa rin, malayo dun sa ibang Isuzu hehe. Thick leaf pack + light rear end = horse-like ride when unladen. Sana bawasan nila yung leaf pack, most owners never really get to use the full payload capacity.Last edited by Wh1stl3r; May 31st, 2011 at 01:55 PM.
May 31st, 2011 02:40 PM #19
Yeah. Instability in handling is due more to the height and suspension tuning of the Fort and the Everest than due to what suspension they're using. The Alterra's low ride height, I feel, is more of a factor than anything else in the equation.
Leaf springs don't have to be stiff... but that's how they tune Isuzus. Makes for better load-carrying capacity, I guess.
May 31st, 2011 08:03 PM #20
Agree with you bro, bawasan or ireverse yung isang maiksi would do although i would reco na palitan ng medyo mas maikling molye (acting like a spacer) na leaf spring para mataas pa din tindig but softer na ride. works wonder talaga lalo na if hindi nga heavy duty hauling yung pick-up.
