Results 1 to 20 of 20
    if magpapalit lang ng isang gulong, may procedure ba na dapat sundan? kailangan pa ba irotate or watever?
    wer's a good place selling bridgestones? turanza 195/60 R14 yung nasa car now.
    and san ok magpareface ng rotors? napansin ko while checking the tire may mga guhit guhit na yung rotors ko sa harap e.
    thanks
    put the new tires up front!
    best to change the tires in pairs and put the new tires in front. Keep the other good tire as a spare for future replacement.
    Quote Originally Posted by boybitz
    preferably, change 2 and put them both in front.
    Freddie's Tire Supply - Evangelista 750-4601 Jerry
    had an idea, though, dunno if it's ok.
    what if you evaluated the 3 remaining tires and looked for the least worn and put that up front with the new one, would that be a problem?
    or, if all the 3 tires are worn too much, then why not put the evenly worn pair up front and the new one at the back.
    ewan ko lang. wadya tink bros?
    IMm29, sir di ba dapat yung pinaka ok sa three plus the new tire ang ilagay sa front
    kasi don mo kailangan ng traction eh (saka iwas sabog)
    mura ba diyan kay freddie's???
    preng kimpoy,
    o nga pre. dapat nga yung bago sa front.
    pero, pano naman kung sobrang worn yung 3 (sobra, meaning worn to the extent that there would be a big discrepancy between the new tire and the worn tire, but not so bad yet as to requiring a replacement)? hindi kaya magkaroon ng steering/swerving problem up front coz one tire has excellent traction vs. the other one, so perhaps the car would steer/swerve toward one side? :?:
    kapag siguro sa high speed situation pero kung normal driving condition minimal ( i dont know pre iniisip ko lang as i answer this)
    siguro nga sir mag swerve sa isang side dahil worn out na nga yung isa
    pero bottomline
    dont take chances, lalo na kasama ko family ko, sa tires kasi nakasalalay ang buhay natin di ba,
    Quote Originally Posted by kimpOy
    pero bottomline dont take chances, lalo na kasama ko family ko, sa tires kasi nakasalalay ang buhay natin di ba.
    Right on, kimpOy! :D
    Actually, the one tire scenario is something i thought of when i remembered what we did for my boss 2 years ago. Dapat talaga, 2 ang palitan para pantay. Pero in her case, since about half a year pa lang ginamit yung isang nasa harap, at yung isa naman e nabangketa nya, isa lang ang pinalitan namin.
    ok pa yun sir IMm29, basta hindi yun tipong nakikita mo yung mga wires he..he
    i guess gawin ko na lang spare yung isa. factory spare pa yun e. tapos itrade in ko na lang siguro yung isa.
    btw, i asked around and mga 2k daw yung isang turanza. I'll try calling Freddie's tomorrow.
    salamat po ng marami...
    kimpOy,
    delikado na yun sobra, kung nakalabas na yung ply.
    boybitz,
    good luck. replacing 2 tires is really the recommended solution, but you could try our options on the 1 tire replacement.
    Kung magpapalit ka lang ng isang gulong dahil sa ito ay lat say flat, just use your spare then have the flat tire repaired/vulcanized then ibalik mo ito. Unless your tire is the same size, thread pattern and type as your flat tire then leave it be. The situation is different if your planning to rotate your tires. Most manufacturers recommend rotating your tires every 10k of road use. For new tires always place them in front if your vehicle is FWD and rear if it is RWD. Goodluck.
    or use the brand new and the spare tire (kung hindi pa nagamit) then spare mo na lang yung na flat
    pero bottomline
    Tama ka Kimpoy. Isama nyo na rin sa life savers ang brakes and seatbelt.
    boybitz,
    most goodyear servitek have the machine to reface brake rotors...mura lang ang singil nun....isabay mo sa tire replacement....else bring it sa machine shop....
    salamat.
    Front, front, front
    dalawang bagong yokohama yung nasa front ko mga 3months na ata. parang may singaw yung isang gulong ko sa likod so gusto ko sana bili ng isang bago. kse yung spare ko yung tipong "pwede pa in case ma-flatan ako sa daan" chaka yun spare iba yun mags. meron pa ko isang gulong sa house, btw, goodyear po yung spare at yung nasa rear. yung paglambot naman po is after 3-4 days. maayos pa ba yun o kailangan bili na ng bago?
    yung tire na nasa bahay di na din ganon kaganda mejo may line na sa side.
changing 1 tire
