Results 11 to 20 of 20
- Nov 2002
- 162
November 19th, 2002 08:01 PM #11i guess gawin ko na lang spare yung isa. factory spare pa yun e. tapos itrade in ko na lang siguro yung isa.
btw, i asked around and mga 2k daw yung isang turanza. I'll try calling Freddie's tomorrow.
salamat po ng marami...
November 20th, 2002 11:32 AM #12
kimpOy,
delikado na yun sobra, kung nakalabas na yung ply.
boybitz,
good luck. replacing 2 tires is really the recommended solution, but you could try our options on the 1 tire replacement.
November 20th, 2002 12:06 PM #13
Kung magpapalit ka lang ng isang gulong dahil sa ito ay lat say flat, just use your spare then have the flat tire repaired/vulcanized then ibalik mo ito. Unless your tire is the same size, thread pattern and type as your flat tire then leave it be. The situation is different if your planning to rotate your tires. Most manufacturers recommend rotating your tires every 10k of road use. For new tires always place them in front if your vehicle is FWD and rear if it is RWD. Goodluck.
- 10,620
November 20th, 2002 12:12 PM #14or use the brand new and the spare tire (kung hindi pa nagamit) then spare mo na lang yung na flat
November 21st, 2002 03:58 PM #15Originally Posted by kimpOy
BANNED BANNED BANNED
- 3,790
November 30th, 2002 11:08 PM #16boybitz,
most goodyear servitek have the machine to reface brake rotors...mura lang ang singil nun....isabay mo sa tire replacement....else bring it sa machine shop....
- Nov 2002
- 162
- 152
December 5th, 2002 10:35 AM #19dalawang bagong yokohama yung nasa front ko mga 3months na ata. parang may singaw yung isang gulong ko sa likod so gusto ko sana bili ng isang bago. kse yung spare ko yung tipong "pwede pa in case ma-flatan ako sa daan" chaka yun spare iba yun mags. meron pa ko isang gulong sa house, btw, goodyear po yung spare at yung nasa rear. yung paglambot naman po is after 3-4 days. maayos pa ba yun o kailangan bili na ng bago?
- 152
December 5th, 2002 10:37 AM #20yung tire na nasa bahay di na din ganon kaganda mejo may line na sa side.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
