Results 1 to 20 of 45
    Sep 2013
    Inquired in Shell & Petron in Taft Avenue area para sana sa change ng brake fluid pero wala daw silang service na ganito. May mairecommend ba kayong saan shops maliban sa gasoline station at casa?
    san location mo?
    Sep 2013
    Shaw blvd. area ko... BTW sa lahat ngreply thanks & newbie ako pag dating sa car kaya di ko kaya mag DIY
    Quote Originally Posted by 1D4LV View Post
    san location mo?
    Quote Originally Posted by kimbon View Post
    you can bring it to speedyfix.
    Jul 2011
    DIY
    hanap ka na lang sa youtube ng How-To
    May 2005
    At Toyota Otis, they used a siphoning system which did not require removal of the wheels for bleeding.
    Jul 2013
    Kung DIY person ka, simple lang yan.
    1. First method yung classic. Dapat may kasama ka na taga-press ng pedal tapos ikaw naman ang mag-lululwag ng bleeder screw.
    2. Second method eh gawa ka ng DIY power bleeder. Dami nito sa google or youtube.
    Kung hindi ka naman DIY type, dalhin mo na lang sa suking mekaniko mo at kayang kaya nila yan.
    Wheelers Suspension Haus also has a "brake dialysis" machine.
    Try Goodyear Servitek also.
    Jul 2011
    magkano ung brake dialysis?
    Mga 350 ata... It's like a suction machine operated by their air hoses.
    Jul 2011
    ah pwede na. thanks.
    Sep 2013
    Checked with Wheelers Suspension Haus. 350 pa rin ang labor sa brake dialysis while sa Speedyfix ay 600 ang labor sa bleeding for 30mins to 1 hr. Wala daw ang speedyfix na brake dialysis na ginagamit. I'm guessing na mano mano ata ang pagbleed nila.
    Bat kaya mas mahal sa speedyfix? Given these 2 prices, which service shop would you recommend? Pls help me to decide mga tsikoters. TIA
    Sep 2013
    Sir newbie here. anong purpose po ng brake dialysis? need ba ito before change ng brake fluid since wala naman akong nararamdaman unusual sa braking. Gusto ko lang sana magchange ng fluid as PMS.
    Aug 2004
    Brake fluid absorbs water and breaks down with age. This may cause corrosion and vague braking feel. Dialysis ensures that all your old brake fluid is sucked out and replace with a fresh batch.
    Hanap ka yun Meron vacuum, alam ko sa customer's cradle meron dati.
    Para tangal talaga lahat ng brake fluid mo.
    Dec 2017
    Pagawa mo na lang ₱350 lang labor. Hinijigop yun old fluid using vacuum then meron air compressor. Wala ka pa pagod.
    Pero in this case. Palusot na lang yun. Lahat naman siguro ng mekaniko alam na i-bleed yun lahat ng brakes and hinde lang isa.
Change ng Brake Fluid
