Inquired in Shell & Petron in Taft Avenue area para sana sa change ng brake fluid pero wala daw silang service na ganito. May mairecommend ba kayong saan shops maliban sa gasoline station at casa?
At Toyota Otis, they used a siphoning system which did not require removal of the wheels for bleeding.
Kung DIY person ka, simple lang yan.
1. First method yung classic. Dapat may kasama ka na taga-press ng pedal tapos ikaw naman ang mag-lululwag ng bleeder screw.
2. Second method eh gawa ka ng DIY power bleeder. Dami nito sa google or youtube.
Kung hindi ka naman DIY type, dalhin mo na lang sa suking mekaniko mo at kayang kaya nila yan.
Wheelers Suspension Haus also has a "brake dialysis" machine.
Try Goodyear Servitek also.
Mga 350 ata... It's like a suction machine operated by their air hoses.
Checked with Wheelers Suspension Haus. 350 pa rin ang labor sa brake dialysis while sa Speedyfix ay 600 ang labor sa bleeding for 30mins to 1 hr. Wala daw ang speedyfix na brake dialysis na ginagamit. I'm guessing na mano mano ata ang pagbleed nila.
Bat kaya mas mahal sa speedyfix? Given these 2 prices, which service shop would you recommend? Pls help me to decide mga tsikoters. TIA
Hanap ka yun Meron vacuum, alam ko sa customer's cradle meron dati.
Para tangal talaga lahat ng brake fluid mo.
This is what I found for "brake bleeder":
Top Deals Auto Car Manual Vacuum Pressure Pump Brake Bleeding Portable Repair Set | Lazada Singapore
Pagawa mo na lang ₱350 lang labor. Hinijigop yun old fluid using vacuum then meron air compressor. Wala ka pa pagod.
Pero in this case. Palusot na lang yun. Lahat naman siguro ng mekaniko alam na i-bleed yun lahat ng brakes and hinde lang isa.
