Results 1 to 15 of 15
    Jul 2012
    meron po ba sa inyo nakasubok na magpagawa sa mega motion sa may banawe? ok po ba sila gumawa? di po ba mahal dito? TIA
    I've only gone there once and it was to install the new rear shocks of my car as Wheelers was full. Took them a while to do the job and they did not have the power tools to make the task faster. Can't comment on how they diagnose and repair problems though.
    They had a good reputation in the 90's. They were known to be complete with tools and were very good at fixing problems though they were also known to be pricey. I haven't heard about them for over a decade and I don't know anyone who goes there. If you do try them out, post a review.
    May 2011
    Kaya ba ni wheelers suspension ng fofi sa front? Ano ba symptoms ng sira stab link?
    Nagpa align na ko sa kanila but I still have wheelers do most of the diagnostics and actual work. Next would be Class A motorcraft along retiro (near mega motion). The owner of class a is a car enthusiast also (mr robert ong) but his bays fill up fast so better come in early
    May 2011
    Hindi ko makita yung Class A motorcraft along retiro. Tnry ko sa mega motion okay naman pero wala sila stab link sa tsikot ko pero wala naman ako binayaran nila sa pagdiagnose ng sira. Bumili nalang ako pyesa sa mazford and dun ko narin pinagawa... Loose na yung stab link sira naba talaga yun? Pero na lessen naman yung ingay sa rough road pero meron parin suspect ko is bushing something. Hindi naman siya kalamapag feeling na hindi smooth sa rough cement road
    Quote Originally Posted by 3GEMS View Post
    suspension wear-and-tear repair is usually straightforward. if it moves too much or makes a sound, it needs replacement.
    i have mine done by mechanics tambaying beside the auto parts stores.
    but the first question i ask is, "may piyesa ba itong kotse ko diyan?" kung wala, i drive away.
    after the suspension repair, i have it aligned at nearby servitek. ok naman.
    Class a is retiro (ns amoranto) near the corner of biak na bato if im not mistaken.
    May 2011
    Dr. D - sira na nga loose sobra nagagalaw with my fingers lang. Grabe kasi daan sa metro manila hindi maiwasan mag menor sa ibang lubak lalot nagmamadali.
    Doc otep - naka apat na pabalik balik ako near mega motion wala talaga. Hindi na ako umabot sa biak na bato takot ako sa carnapper .
    Ironic puro med professional tau dito
    who else has the intelligence, the money, and the time management tolerance? heh heh heh.. (a joke, of course! apologies in advance to the un-intended victims..)
    besides, it makes for good relaxation..
    May 2011
    Guys i need your advise. Under warranty pa yumg oto. May problem sa suspension nag rattle sa rough road. Pinatingen ko sa labas ang diagnose nila is sira stab link. Nagpalit ako left and right stab link pero andun padin yung rattle sa rough road my next plan is sa casa ko na pa check up. My question is may possibility ba ivoid nila warranty ko sa pinalitan ko stab link example na nakadiagnose sila ibang sira na hindi naman related sa stab link pero sa suspension. Plan ko kasi ibalik yung OEM na pinalitan na stab link bago ibalik sa casa kaso sira nadin kasi yun baka yun din diagnose nila so papalit aq ulit stab link from casa tapos nde rin magawa rattle sa suspension. Hope nagets nyo point ko.
    Jun 2005
    anong kotse? kung vios yan, may technical advisory yan about suspension problem involving the lower suspension arm assembly and stab link.
    anyway, short answer is yes lalo na kung iba na ang nakalagay na stab link. sobrang halata na may gumalaw
    bring it to the casa first.
    if the warranty is still in force, then there is the chance that your problem may still be fixed free of charge, even if the problem is suspension..
    (see sirkosero's message above. it appears the manufacturer issued a sort-of-recall announcement..)
    May 2011
    *sirkosero - fiesta bro.
    *Dr. D - problem is baka hindi cover lalot nagpalit ako stab link. Magakron sila dahilan. Pero baka pag binalik ko yung sira stab link bago ibalik sa casa baka yun diagnose nilang sira kahit lam ko ng hindi yun bec. Pinalitan ko na sa labas pero andun parin rattle.
    May 2011
    Update on this:
    Pinalitan na ng casa lower arm under warranty. Nabawasan lang yung garalgal sa rough cement or asphalt. Dinala ko sa ibamg casa shock absorber daw ang problem. Possible kaya yun? Okay naman kasi bounce ng sasakyan magaralgal lang talaga para may maluwag ng bolt ramdam sa kaha ng sasakyan. Nakailang balik narin ako sa servitek solid naman lahat ng pang ilalim. I need your inputs guys. Pwede ba ganun symptoms ng bad shocks. And any other shop mabusisi sa suspension. TY
ok ba sa mega motion sa may banawe for suspension problems???
