Results 11 to 20 of 22
- Aug 2005
- 227
August 17th, 2006 01:27 PM #11servitek sa timog ave. 1,300.00 camber alignment sa front lang yan, sa likod another 1,300.00 ulit. 6 months ago na price yan.
August 17th, 2006 02:08 PM #14
Just had my front tires replaced last week sa Servitek, wala na kasi sa hugis. Tapos papa-align ko na rin sana, kaso nung tinignan ng technician yung steering linkage, may tama na daw ball joints ko, kelangan nang palitan.
They gave me an estimate of 3,300 for aftermarket ball joints (4 pcs.) tsaka 2,100 labor (kasama na alignment and camber correction). Hindi muna ako nakapag-avail kasi kinulang na budget ko. El Dorado naman gave me a quotation of 1,400 for each original Mitsu ball joint. Nagtaka lang ako kasi sa tinagal-tagal kong magpa-PMS sa casa, sa Servitek ko pa malalaman na may kelangang palang palitan.
August 17th, 2006 02:24 PM #15
dapat paayos mo muna ang pangilalim mo bgo ka paalign kasi paginalign yan sa sirang pangilalim mo mawawala nanaman sa alignment once nang paayos ka na ng ballljoint. sa ZEE nag ininject sila ng balljoint P250ea and labor P300/side, free alignment,yan ang rate nila last year noong magpagawa ako or nagtaas na sila
- Dec 2005
- 52
August 17th, 2006 04:32 PM #17I have a similar problem... kaya lng mine is Honda City 97 Exi...problem with camber (front right) and caster, kaso sabi sa pinuntahan kong shop fixed camber/caster daw yung oto ko....
Ano kaya pwede kong gawin? Balak kong papalitan yung suspension arm kaya lang worth ba?
August 18th, 2006 01:33 AM #18
Eh ang honda civic SIR na aalign po ba kasi naka negative ung front tires ko ehh??
August 18th, 2006 01:42 AM #19
mamar, I think you can align the front using an aftermarket camber bolt.
mas negative ba ang front mo kaysa rear? If so, that's the same setting I have to reduce understeer. Well, no more than -1.5 camber shouldnt hurt the tires as much.
my FWD integra alignment settings:
FRONT:
More Negative -1.5
More Toe-Out
More + caster
REAR:
More Positive Camber 0.00 or -0.5
More toe-out
August 18th, 2006 01:49 AM #20
Mag kano po kaya ang camber kit na pang sir and saan po kaya makakabili nito??
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
