Results 1 to 6 of 6
- Feb 2003
- 618
September 25th, 2004 12:13 AM #1hi, nag mimisalign ba yung takbo ng car kun sira na ang wheel bearing?... is there any way to find out kun sira na ito, like shaking the tires? .... or maririnig ito while driving? thanks
September 25th, 2004 12:35 AM #2
after driving for say around 20 kilometers, feel your rims/wheels. pag uminit,
most likely na kailangan nang palitan ang bearing mo...
- Feb 2003
- 618
September 25th, 2004 01:26 PM #3sir bardigones, umiinit naman talaga ang gulong kapag tinatakbo for even a few kilometers, right? (ndi ako pilosopo...)
September 25th, 2004 02:07 PM #4
Nangyari na sakin yan... kpag lumiko ka ng kaliwa at kanan lalong malakas ang ingay nya. kya wag munang patagalin yan ksi mangdadamay pa sya ng ibang pyesa.
September 25th, 2004 02:24 PM #5
First thing that you could assess the bearings are cluprit, whirling noise while travelling in neutral, no brakes and listen to where and what sound emits from.
How did you determine the vehicle travelling in misalignment? Was it based on the sterring wheel alignment?
You can also visually check on each wheel by jacking it up. hold the tire at 12 & 6 o'clock hand position and check for excessive play. Holding it at 9 & 3 o'clock position could also check on tie rod and ball joints. These are for the front wheel. To check the rear wheels, jack one wheel up and place hand on 12-6 position. A 1 inch movement could indicate that bearing lock has loosened or bearing needs re-packing or worse, replacement.
HTH
September 27th, 2004 10:33 PM #6
pag na misalign ang tires mo eh grabe na ang sira ng bearings and possibly maalis na ang tires mo.
just did a quick search... BYD e6 - Wikipedia Yung 1st Gen BYD e6 pala was released in 2009...
China cars
