Results 1 to 14 of 14
    Jan 2010
    I have a Honda Civic 96 LXI and pag sinasagad ko ang brake pedal while moving (i'm moving in a parking lot kaya nasa menor lang ako) nag-stop then umaandar slightly ang kotse. Natakot ako nung unang mangyari kasi akala ko nawala yung brake ko. Then nirelease ko yung brake pedal then inapakan ko ulit, kumagat naman ang brake. Nag stop yung kotse.
    Ano kaya problem? San ko pede ipacheck to (south area preferably)?
    Quote Originally Posted by roninxt View Post
    check your fluid levels, worn brake pads, even your hydrovac.
    Jan 2009
    happened to me last month. sa brake master (thing below the reservoir of the brake fluid) problem. mekaniko replaced something inside and the problem was gone. total cost with labor -> less than 500 pesos.
    Simptoma to na may tagas yung brake system, and tumatagas yung brake fluid o may pumpapasok na hangin. Paki check yung brake fluid level. Kung mababa ito, ibig sabihin nito, may tagas talaga. Usually brake master repair kit lang ang papalitan. Kung bagong palit lang yung brake master, at marami pang brake fluid, kailiangan i-bleed/purge yung hangin.
    Jan 2010
    Thanks. Papacheck ko to sa mekaniko.
    Jul 2010
    ASAP bro, preno yan...delikado....
    Nov 2003
    if it's the brake master (or clutch master/slave for that matter), replace the whole thing. the repair kits will last for a very short time and you'll end up with the same problem all over again.
    sir ask ko lang, napansin ko kasi kapag nag-apply ako ng break may naririnig po ako na "dug-dug" sounds, naririnig sa right portion ng auto, ano po kaya ito?
    GUD PM MGA BOSS.
    Related to this thread about my break problem. Bagong palit po Break Master Assembly ko. problem is masyado malalim preno, and once na umaapak ako sa preno, nakaka rinig po ako ng pump ng air. Saan po adjustments ng preno, gusto ko medyo taasan.
    Nov 2003
    first of all, it's BRAKE not break.
    if the pedal is low that means either there is air or the pushrod of the brake master needs to be adjusted.
    May 2009
    "Have a break, have a kit-kat"........
    "Push the brake, you'll make a full stop"........hehehe
    To add up also, if the brake pedal moves further down to the floorboard, or several pumps will do the magic, it could be also the rubber parts and the return springs are losing elasticity.
    mahirap na mawalan ng brakes. tumirik na makina kesa mawalan ng preno.
    but in your case, baka simpleng bleeding lang kelangan
    tsaka dapat nai-bench bleed muna yung master assy bago nainstall.
    Quote Originally Posted by miked View Post
    +1, bleeding kight solve it. If not, check for leaks on your brake system with the help of a reputable auto shop.
    Ok mga sir, sensya na, BREAK time ko kasi ginawa ito dito sa office.hehe
    BREAK tuloy na-itype ko..
    Pinalitan narin nila yung mga goma sa bandang front wheel, pati piston. Dati kasi double pump bago kumagat preno, ngaun isang apak nalang, but sobrang lalim naman and my airpressure ako naririrnig. I have an idea now kung ano pagagawa ko.
    Thanks..
    Hi! My dad also owns a honda civic LXI na may problema din sa brakes. this problem had been recurring for i think three years na. Everytime nabibigla ako ng tapak sa preno, (for example my biglang tumawid or biglang brake sa harap.. ganung type ng pagpreno) yung mga next na tapak ko may tunog na parang may gravel sa gitna ng brake pads and ng rotor disc. Sabi ng tatay ko madumi lang daw. kaya everytime na magkakaganoon, binubuksan nya yung brakes and nililiha para pagpantay, tapos yung disc nililinis din. Hindi ako naniniwala na madumi lang. Kasi parang naisip ko, cars are not made that way na pag biglang tapak e dudumi agad. ang tingin ko parang once na nadiin ka ng tapak, may bagay na hindi bumabalik or nagrerecoil kaya may sumasayad the next time na tumapak ka ulit sa brakes. May alam ba kayo na ganitong case and anong tingin nyo sira nito? Saka kung may alam po kayo na pwedeng pagpaayusan nito.. yung talagang magaling, kasi i tried having this thing fixed in one shop, sabi kailangan lang daw irephase yung disc, pero eto, hindi naayos. I'm living in Malabon. Kahit po Caloocan, Manila, basta hindi sobrang layo and guaranteed na maayos yung sasakyan..
Brake problem
