Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    May 2005
    What kind of maintenance are needed to be performed to the brakes (ie. brake cleaning ? ) after crossing flood waters ?
    After crossing the flood yesterday, immediately experienced some metallic noise which promptly disappeared after pumping the brakes repeatedly to dry it out.
    This morning, about to drive out, when the brakes made some audible noise like "grrggghh, grrrghhh " . Disappeared again once I drove out. Just this lunch, the brake seemed nervous, shaking. and now I'm hearing some metallic again.
    Note none of these happened before yesterday's flood crossing. and Note most of these noise manifestations occurred during initial brake use only.
    Will brake cleaning/lubrication cure these noises ?
    Thanks!
    Check to see if any debris was caught between the caliper/pad and the rotor.
    This could very well be a possibility if the brakes feel odd.
    Pansin ko sa brakes namin especially during the rainy season, the brakes make initial sounds when natalsikan ng tubig and a slight coat of rust develops on the disc rotors (madalas mapansin when left overnight). Nawawala naman after initial use though.
    Could be some stuck foreign objects. For starters, you can buy some 3M brake cleaner, open up your brakes and give them a nice cleaning.
    In your next service stop, drain and then put in some fresh fluid.
    Vinj, what brand of brake fluid would you recommend?
    There's always good 'ol Prestone for everyday use. Just go with regular DOT3 unless you're the type who's into track days. It's more important to change and flush every so often, especially if you wade floods (i do my brake system flushes every 20,000kms).
    The branded brake fluids i see are Motul and RP. Pricier though.
    If you can find the Bendix fluid, that seems okay too (i'm using this on my 9th gen Altis now). I bought mine at the Motorshow last year.
    May 2005
    If its the disc brakes in front, I dont see any debris stuck.
    Probably it got submerged, moisture retention and lost some lubrication.
    As for vinj's suggestion of DIY brake cleaning, I think thats way beyond my skill set. I'll probably have to turn to a shop do this (ie. speedyfix).
    Also I haven't changed brake fluids since new. The fort is 6 yrs and its a low mileage weekend/coding vehicle. 13,6xx kms only. I'm worried about the fluid change is that not all shops are competent enough in doing the change without allowing pocket of air to be stuck in the brake lines.
    When I used to bring it to Toyota casa, the SA use to " insert " the brake cleaning services in the PMS. They would remove the cover on the drum brakes at the rear and spray lots brake cleaner on the springs, brake shoes, etc...
    My question is, is brake cleaning a necessary preventative maintenance or is it about as useful as engine flushing, diesel fuel treatment , as well as other casa hokus pokus, etc
    Oct 2011
    Sir Vinj, okay rin ba ang Mag1?
    Oct 2011
    In my case, when I do tyre rotation every 10k, kasama na ung pag check ng disc brake pads including the brake shoe and they would clean it as part of pm. mura lang naman kaya hinayaan ko na lang.
    The hardest part of brake cleaning is lifting the car and removing the tires actually. You can bring it to the gas station with a lifter and have them mount your car, remove the tires, pads/drum cover tapos ikaw mag spray ng brake cleaner. It's nice watching all the dirt go down.
    Havent tried mag1 but i guess it should be okay for the daily grind. The usual thing people should watch for in brake fluid is it's hygroscopic properties. Some fluid types can be more hygroscopic then others so to keep your brake system clean, you'd have to change more often to get rid of corrosion inducing and brake feel lessening moisture buildup.
    Jun 2008
    Madali lang yang cleaning & change fluid basta handa ka dumihan ang iyong kamay. Bleeding air thoroughly from the brake hydraulic system is not a hard thing to do. all you need is guts, tools & correct procedure to do this thing. no need to go to fancy auto shop. It is recommended to clean the calipers & brake cylinders day after ka lumusong sa baha para hindi kalawangin & stuck up ang preno especially kung hindi mo gagamitin ang car for few days there after.
    May 2009
    to ts,
    if the sound occurs during the first few stops in the morning, afaik its normal and no service action is required. the brakes are simply cold. you may want to clean the brakes anyway kung di ka mapakali. me uses warm water with lotsa joy dishwashing liquid kung walang brake cleaner. buhusan mo disc habang iniikot ito. 3M, wurth sabesto, prestone are among the top brands of brake cleaner that i prefer. mas mura nga lang kasi yung sabesto iirc.
    madali talaga kalawangin ang brake discs due to the material used which is cast iron. kaya preferable na idrive regularly ang sasakyan para mawala kalawang. kapag kinalawang ng todo ang disc hindi na pantay ang braking action.
    hth
    Oct 2011
    Saan auto supply within Manila area na nagbebenta ng Bendix brake pads? and how much ito?
    Sep 2012
    Yes! during flood it is quite difficult to manage brake of vehicle. When we apply brake it got stuck in the tires actually. Do any one know what to do in this condition. It would be good if anyone help me!
    flooding emergency service jacksonville
    Jun 2007
    Quote Originally Posted by miked View Post
    to ts,
    hth
    kaya pala if you leave the auto to dry after washing eh nagkaka rust. pag ginamit na, nawawala naman
    Aug 2010
    parang may nakita ako sa recto, bet. benavidez and masangkay.
    you can also try bosch brand.
    Oct 2011
    Quote Originally Posted by trucker111 View Post
    Pag Bosch malamang meron sa Warren. Okay rin ba ang Bosch na brake pads? I mean, kakapit pa rin ang brake pag baha? ung R-Specs daw kasi wala na brake during flood.
    Sep 2005
    Wag kayong bumili ng R-Specs na pad, walang kwenta ang quality nyan ngayon.
    Oct 2011
    Quote Originally Posted by CoDer View Post
    boss Coder, okay ba ang Bosch pads? yan na kukunin ko kung hindi ako makahanp ng bendix.
    Sep 2005
    Wala akong experience sa Bosch pads Retz, but I can attest to the performance of Bendix. I am currently using Bendix General CT both for front and back of my ride. Tanabe sana sa front then Bendix General CT sa back, kaso walang tanabe dito sa province.
    You won't have a hard time getting bendix pads, madami yan sa suking autoshop. Go for Bendix Metal king pag sa SUV mo gagamitin such as fortuner.
    Aug 2010
    ok naman. you can compare it sa store sa recto.
Brake Maintenance After Flood fording
