Results 21 to 27 of 27
- 52,830
September 29th, 2017 12:28 AM #21
- Dec 2016
- 16
September 29th, 2017 11:03 AM #22bata pa ako na samin ito. mga 20+ na po siguro. LEC daw model sabi nang nakausap kong mekaniko noon. kaya lec lagi pag naghahanap ng parts haha
- 52,830
September 29th, 2017 11:09 AM #23kung ako si ako, ay papalitan ko na yung both cylinder and tubing.
you can try the tubing first. if that doews not work, cylinder and tubing.
- Apr 2009
- 429
September 29th, 2017 12:01 PM #24
- Dec 2016
- 16
September 29th, 2017 03:41 PM #25pag tinawag po bang OEM ito ba yung part/item na katulad mismo ng papalitan na item na nasira? example nung pagka bili ng brandnew na kotse ang installed na sparkplugs ay BrandA. BrandA is the OEM, which is the supplier of that specific car during its production period. BrandB=are those ngk, bosch, denso etc. which are called replacements.
tama ba pagkakaintidi ko sir?
pag sinabi din po ba ng shop seller ay nagtitinda ng Original, ibig ba sabihin nun ay OEM? oem=original?
other terms din po ba ng:
Oem= original? Stock?
replacement= aftermarket parts?
- May 2011
- 481
September 29th, 2017 05:23 PM #26
- Apr 2009
- 429
September 30th, 2017 12:40 PM #27OEM - original equipment manufacturer. yep bone stock. eg: Denso, NGK, etc,. These things you usually get them from casa or brand specific specialty shops outside casa. OEM are parts the car manufacturer installed in your car during assembly. Analogy is, OEM are like meds that are made by the innovator and the generic drugs are like the replacement parts you get from your suking autosupply. There are good generic drugs and good replacement parts like for eg; 555 brand for suspension, ViC for filters, Aguila for autoglass, and the list goes on.. you will know this things if you are the one maintaning your car first hand. But some parts are better replaced with OEM if you know what i mean....
i wouldn't. and neither will the majority, probably. pagawa ko na lang when the need arises. the...
Mitsubishi Xforce
