Results 1 to 20 of 23
    Sep 2019
    Hi Guys,
    Need your advice on this.
    Napansin namin medyo bumababa yung brake fluid level ng car. Siguro mga 1 tablespoon dinadagdag namin every 1 to 2 weeks?
    Not sure if may slow leak ba sa bleeder valve kasi pinableed namin sya last October or baka dahil worn out na din brake pads?(mag 4.5+ years na yung brake pads).
    Yung father ko nirerefill nya ng brake fluid above ng konte dun sa full indicator dun sa reservoir para daw mas nakikita nya if bumababa yung level ng brake fluid. Ok lang ba yun or dapat hindi lumagpas sa full indicator? Thanks.
    Sep 2010
    Quote Originally Posted by tensazangetsu View Post
    Hi Guys,
    Possible dahil sa brake pad mo sir. Try to replace the brake pad po and monitor if magbabawas parin ang brake fluid.
    HTH!
    Palitan mo na pads.
    Sep 2019
    Thanks mga sirs! Magcheck na ako ng brake pads. Might try yung brembo brake pads siguro mas mura sya dun sa original akebono brake pads ng mazda3 ko.
    have the brake pads looked at. if the thickness is ok then its not necessary to change. the brake fluid on the other hand probably needs changing if its over 4yrs.
    Sep 2019
    Thanks sir. Kakabrake fluid change lang din nung October. Kaya naisip ko din if baka hindi nahigpitan yung bleeder valve msyado during the fluid change?
    Or most likely dahil sa worn out brake prads since sobrang slow lang nung pag decrease? Wala naman ako nararamdaman na difference sa pag brake parang normal lang din naman.
    I will drop by sa Speedyfix siguro sa Friday to have them check just to be sure na din. Thanks sirs!
    Jul 2013
    dalhin mo sa gas station tapos paangat mo yung car... tapos tignan mo kung may leak yung valves...
    di naman madali matuyo ang fuid... so makikita mo yan
    check mo na din yung master
    Hi Guys,
    brakepads do not normally wear that fast... unless your rotors are sandpaper-lined.
    my guess is, you're leaking brake fluid.
    hoist the car up and take a good look around the brake lines and brake mechanisms. look for something that's wet with brake fluid. don't forget the brake master.
    He said last replacement was 4.5+ years ago.
    Jun 2005
    4.5 years for the brake pads. Yung fluid was about 2 months ago.
    Di naman impossible na maglast ying brake pads ng ganun katagal. Yung 2008 vios ko still had original brake pads when sold in february this year with lots of meat left even after clocking 120k+ kms.
    Sent from my MI MAX 2 using Tapatalk
    Sep 2019
    Went to Speedyfix kanina and they said na yung brake master yung may leak and need palitan.
    Although wala naman din ako napansin na kakaiba sa pagbrake, normal naman lahat. Yun leak nya super slow lang talaga. Ginamit namin sya kahapon and kaninang umaga hindi naman bumaba yung level.
    Need ko na maghanap ng brake master since wala daw sila at medyo recent pa yung car. Thanks guys!
    May 2017
    yup, mas usual suspect ang brake master kapag nagbabawas ng fluid kaysa sa brake pads
    Jan 2008
    Anong car ba yan? Usually yung kit lang pinapalitan.. wag mo patagalin kasi corrosive sa paint yan..
    Hi Guys,
    check mo rin kulay ng fluid if darker or contaminated. pabukas mo 4 wheels and pa inspek mo. meron leak yan mahina.
    While at it, check the fluid's water content w/ a DOT3/4 calibrated fluid hygrometer.
Brake fluid level decreasing very slowly?
