Results 1 to 10 of 15
- Apr 2009
- 272
- Jun 2005
- 3,774
June 24th, 2017 12:15 AM #2
- Jun 2011
- 134
June 26th, 2017 05:58 AM #3Check for fluid leak on flooring under the brake pedal.Maybe the fluid leaks inside (pushod connecting the brake pedal and the brake master cylinder).
- May 2011
- 481
June 26th, 2017 02:44 PM #4If your exhaust fumes smell sweet and your spark plugs are glazed, it indeed is leaking brake fluid past the master cylinder to the vacuum brake booster and into the intake manifold.
- Apr 2009
- 272
July 24th, 2017 04:58 PM #5so whats the best solution for this since i cant find any leak between the brake master cylinder and booster.
should i just replace the master cylinder with a new one? replace the booster? or buy a brake repair kit?
- Nov 2008
- 641
July 24th, 2017 05:58 PM #6One way of checking if it leaks through the hydrovac is to pull off the vacuum hose which connects the hydrovac to the intake manifold. If there are presence of oil or fluid, then it is precisely leaking. I would suggest you to replace the entire assembly instead of the repair kit only, as the diaphram in the hydrovac has already been soaked in fluid, which eventually will fail afterwards.
- Apr 2009
- 272
July 24th, 2017 09:55 PM #7
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
