Results 1 to 4 of 4
    Jun 2006
    How do you replace the brake fluid in a car equipped with ABS? Is it the same procedure as cars without ABS? How do you keep air from entering the ABS module?
    Remove the fuse of the ABS first.
    Then proceed to the normal way. Just bleed it fully the ABS will be fine.
    How was your class with Mr. Soncayaon?
    Jun 2006
    ok naman graduate na. Might continue with it, not yet decided. Yun nga lang this wasn't part of the sylabus.
    Nov 2003
    no need to remove the fuse. the abs module stays closed naman under normal operation until it is sent signals from the wheel speed sensors and the abs box.
brake flud replacement
