Results 1 to 4 of 4
Tsikot Member Rank 4
- Jun 2006
- 2,605
June 30th, 2007 10:48 AM #1How do you replace the brake fluid in a car equipped with ABS? Is it the same procedure as cars without ABS? How do you keep air from entering the ABS module?
June 30th, 2007 12:35 PM #2
Remove the fuse of the ABS first.
Then proceed to the normal way. Just bleed it fully the ABS will be fine.
How was your class with Mr. Soncayaon?
- Jun 2006
- 2,605
June 30th, 2007 06:33 PM #3ok naman graduate na. Might continue with it, not yet decided. Yun nga lang this wasn't part of the sylabus.
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 3rd, 2007 11:04 PM #4no need to remove the fuse. the abs module stays closed naman under normal operation until it is sent signals from the wheel speed sensors and the abs box.
Neither's mine. 3 yrs old and no issues whatsoever. Initial 2 PMS lang sa casa, the rest is OC...
Suzuki JIMNY [merged threads]
