Results 1 to 9 of 9
    May 2008
    is there a place where i can buy one way brake bleeder screws anywhere in mm. its a pita when you want to bleed the brake or clutch system and there is no one to pump the pedal.
    Jul 2003
    Quote Originally Posted by goldrat View Post
    type "DIY power brake bleeder" in google.
    Feb 2009
    Quote Originally Posted by fourtheboys96 View Post
    a cheap and available material to do this is a section of a rubber vacuum hose about two inches long, slit about 1/4 inch with a razor blade in the middle. one end plugged, the other end slipped onto the bleeder screw head. pressure from the brake master cylinder pushes the air out of the slit, upon return of the master cylinder, the slit rubber hose partially closes enough not to allow air from getting sucked into the brake cakiper or wheel cylinder.
    Jul 2003
    good idea. however, there is a possibility of air coming in from the thread of the bleeder screw. the bleeder screw still needs to be un-tightened before you can bleed the fluid.
    Feb 2009
    i have used this for years, the surface tension of the brake fluid on the threads makes it partially airtight and the speed of the master cylinder piston return is way much faster than the tendency of the air to reenter the lines. or you can drill one sacrificial bleeder screw straight down from the outlet end, when the bleeding procedure with pedal pressure is done, continue with the gravitational bleeding and then you reisntall the unmodified bleeder screw
    Jan 2008
    a friend, neighbor, relative, or anyone that passes by your location that can help is the best solution to the problem... think safety
    Jun 2008
    Thanks sir. I got the idea, actually first time I read this diy procedure. +1 karma to you. brgds.
