Page 1 of 4 1234 LastLast
Results 1 to 20 of 93
    Mar 2007
    Hello, I need some help here. Sorento 2009 ko ( d4cb vgt ) always na mimis align yung steering wheel ko.
    2 years na ako pabalik2x sa ibat ibang shops. Nareplace narin lahat, ball joints, suspension arm taas at baba etc. Bumabalik yung misalignment niya after some time. If the streering is straight, car goes right.
    Dati pina adjust ko after how many weeks sa left siya lumiliko.
    Pansin ko lang bumabalik talaga yung pagka misaligned niya after several weeks or months. Either paleft or pa right.
    Ano kaya ang sira? Napapagod na ako kakabalik ng shop eh. Just now nag manifest yung misalignment niya. Kagabi ok pa. Ngayong hapon biglang paright na ulit if straight steering wheel..
    Sent from my SM-A605G using Tapatalk
    Quote Originally Posted by suysuy View Post
    are the tire pressures consistent?
    Jan 2008
    Na check mo na ba yung bushing ng rack and pinion mo? Baka durog na yung bushing kaya nag shift yung rack ang pinion assembly
    a knock would be excibited if these bushings were bad...
    Jan 2008
    It depends how bad are the bushings.. the bushings might be loose not clamping the assembly in place.. if its worn out the steering assembly might shift to either side resulting to mis alignment
    good valid points. I remember removing the subframe and jackets were the only way to inspect these visually...
    Mar 2007
    This might be it. Broken bushings apat lahat. I saw the rubber, all cracked. A good mechanic must have seen these cracks the first day I bought it sa shop.
    Mar 2007
    Two weeks ago may clunking sound sa front side during full turn, reverse. Bad cv joints? Part time 4wd pala to.
    Steering is off. 11 oclock position to drive straight. Kahapon center pa siya.
    if the car seems to drive mis-aligned, as in, may kabig, despite the good condition of all the metal parts,
    perhaps it is your tires, sir. out of round na or "oblong". replacement is the only option.
    Aug 2017
    I second this motion, hehehe... with stock engine's as well.
    Do the simple and inexpensive checks 1st, tire pressure and inspection of the tire vs being oblong is free.
    Then move on to the other suggestions like the CV joint and rack n pinion checks.
    Jan 2008
    Steering is off, not veering? If you put the steering at 11 o'clock position the car goes straight?
    Clunking sound on full turn or reverse might come from the cv joints. Check the boots it still ok. Try cleaning the joint and replace the cv grease
    Mar 2007
    Yup its just off, not veering. Car goes straight at 11 position.
    New tie rod ends
    New lower suspension arms
    New upper suspension arms
    Still, alignment is off
    Apr 2012
    Is it the same as what they call stab clamp bushing?
    Sent from my SM-J730G using Tapatalk
    Jan 2009
    How about torque steer from the part-time 4wd?
    Does the vehicle veer left or right during acceleration, deceleration, coasting, etc.?
    Just putting this up there.
    Mar 2007
    Steering wheel returns to 11 oclock position after turning which is when the car drives straight. If steering wheel is center, the car moves to the right.
    Jan 2009
    3 things needs to be aligned in this order:
    1. Steering rack
    2. Steering wheel
    3. Wheels
    Everything needs to be centered around the steering rack. Before doing anything else, this has to be set at dead center. The steering rack has a 'natural' center where steering assist is neutral.
    Next, with the rack centered, the steering wheel should naturally be at 12 o'clock (if it is still unmodified from the factory). If not, the steering wheel needs to come off the column and lined up to 12 o'clock. Once lined up, a holder is typically used to make sure it doesn't move while the rest of the steering components are aligned.
    Finally, the tie-rods are adjusted so the individual front wheels are aligned to the proper toe-in and other parameters designed for that car.
    Steering wheel not-centered problems may arise when lazy technicians just remove the steering wheel from the steering column and reattach it so it lines up at 12 o'clock, without taking into consideration that the steering rack also needs to be at dead center.
    Jan 2008
    99% that your rack and pinion assembly shifts from either side. Try to move the steering wheel to the left or right with engine off (no power assist) to confirm its shift.
    Jan 2009
    Stabilizer clamp bushing is not the same as rack and pinion bushing.
    Apr 2012
    Quote Originally Posted by hilldweller View Post
    Thanks for clearing out
    Mar 2007
    All 4 tires are new. My guess? Baka loose yung mga bolts used to align the wheels? Possible ba yun? Na as short as 3 months nagiging out of alignment siya dahil hindi mahigpit
Steering wheel alignment issue
