Results 31 to 40 of 71
July 10th, 2006 09:39 AM #31
as requested by vinj:
http://img.photobucket.com/albums/v3...DSC04262-1.jpg
not mine, but same kind of brakes sans the cross drilled rotors.
July 10th, 2006 12:50 PM #32Originally Posted by OTO
Di naman inadequate for the VTi, but given the speeds the SiR can reach, it ought to have less pedestrian brakes.
But don't forget to get better rubber while you're at it, Mamar. Brakes are worthless if your tires aren't up to the task.
July 10th, 2006 03:09 PM #33
wla naman po cguro problema sa goma ko ksi naka advan po ako! siguro try ko po muna palit na magandang klaseng brake pads!
October 3rd, 2006 05:03 PM #34
Guys malaki ba talaga differnce ng stoping power ng type-r na brakes kesa sa stock brake ng SIR?
nag palit nako ng magandang brake pads eh ok naman lumakas naman preno ko pero i want more stoping power eh!
October 3rd, 2006 05:46 PM #35
kunin mo yung greddy tulad ng nasa 350z sa carshow. 500k ata yung set na yun (F & R)
October 3rd, 2006 05:49 PM #36
October 3rd, 2006 11:48 PM #37
October 3rd, 2006 11:50 PM #38
October 3rd, 2006 11:55 PM #39
75k is a good deal. Also try hawk pads.Do not use Metallic pads it will warp your rotors,it's just a matter of time.
Tsikot Member Rank 5
- Nov 2003
- 3,849
October 4th, 2006 12:11 AM #40you'll have to differentiate between brakes.
4 piston calipers should be around $2k up, 6 pistons like the s2000 mga 200k for the front, 8 piston yata yung sa 350z will be even more expensive.
