Results 1 to 10 of 71
June 23rd, 2006 08:33 PM #1
Mga guys help me out may nakita kasi ako nung isang araw sa surplusan na 13inch rotors for my civic nag tataka lang ako kung mag kakasya sya kasi ung mag ko 15 inch lng ehh iniisip ko bka sumabit na ung caliper ko sa mags pag nag palit ako ng malaking rotor! Help me out naman jan mga gurus! TIA
June 24th, 2006 03:12 PM #3
That's what I would say... besides, hindi ba 5-stud hub yung nasa big brakes? Is this aftermarket ba or surplus off an Integra?
Malabong magkasya yung 13" sa 15" na mags, even if you have the calipers shaved down.
Toyota is my choice
- Aug 2005
- 2,063
June 24th, 2006 11:34 PM #5Originally Posted by Mamar
if you want more braking power, you can simply upgrade your brake pads.
June 25th, 2006 12:54 AM #6
Go with the pads upgrade first (bendix metal kings, project mu, etc...);it's worth its weight in gold.
June 25th, 2006 12:23 PM #7
Upgrade your brake pads instead of getting bigger disk for the front. If you do decide you want bigger brakes make sure you get the full kit because just changing the front disk without upgrading your brake booster and changing your brake bias to match can actually cause you to have longer braking distance. Also a 13" disk will not fit in a 15" rim.
June 25th, 2006 10:59 PM #8
you can also upgrade to steel braided brake lines. last upgrade lagi ang bigger discs.
June 26th, 2006 11:00 AM #9
unless you are into circuit racing... upgrading to bigger discs are not worth it.
Toyota is my choice
- Aug 2005
- 2,063
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
