Results 31 to 40 of 54
- Sep 2019
- 107
January 13th, 2020 06:55 PM #31Just an update, napa install ko na yung jikiu bushings(bale 4 pcs) sa lower control arm sa Velocity.
So far so good. ride is now better compared sa nung worn out na yung bushings nya.
Hindi naman tumigas yung ride, same sya nung sa stock bushings.
Will still need to test out for few times pa but so far all is good
Kudos to Velocity! Friendly and magagaling mechanics nila. Highly recommended! For any under chassis and suspensions issues sa Velocity ako ulit babalik next time. Labor for the installation and pag press in/press out ng 4 bushings is 1.6k php. Just for comparison M3 quoted me for 2.5k. Cheers!
January 13th, 2020 07:00 PM #32
- Sep 2019
- 107
January 13th, 2020 07:08 PM #33
- May 2016
- 546
January 13th, 2020 08:10 PM #34
- Sep 2019
- 107
January 13th, 2020 08:25 PM #354 lower arm bushings costs me 2.3k+ php. Shipping is free from fitinpart.sg dahil siguro sa magaan lang sya.
Total cost 3.9k(bushings and labor).
I think Mazda 3, CX-5 and Mazda 6 are sharing the same exact bushings for lower control arm.
I was not able to take pictures ng before and after pero nung pagkatanggal ng lower control arm sabi nung mechanic worn out na daw yung bushings ko lalo yung sa kanan(maybe dahil itinakbo pa ng brother ko yung sasakyan nun kahit na flat yung right front tire).
Tested it sa mga usual lubak on my usual route going to work and I can say na ride is much better na compared sa dati.
I will update this thread as well after few weeks of driving it for more observations na din on the new bushings.
- May 2016
- 546
January 13th, 2020 08:37 PM #36Checked with the jikiu site, same exact part numbers for Mazda 3 and CX-5 as you said.
Parati kasi reklamo, hindi raw pwede palitan big bushing sa lower arm, wala kasing nabibili na bushing lang. Sayang naman kasi kung buong arm palitan, kung buo pa naman yung bakal at ball joint.
- Sep 2019
- 107
January 13th, 2020 08:44 PM #37
- May 2016
- 546
January 13th, 2020 08:57 PM #38
- Sep 2019
- 107
January 13th, 2020 09:07 PM #39Yep sir! originally ang plano ko tlaga yung buong lower arm assembly. Halos maiyak ako nun nung binigay sakin ng casa yung quote halos 40k sya pag casa kasama labor haha.
Haven't check yung engine support pa pero tingin ko meron din replacement yan na makikita. Yun isang next daw na baka need ko palitan sabi ng mechanic(although ok pa naman daw) yung stabilizer link buti nalang nasa 1.9k per piece lang sya sa Golden Isuzu hndi masyado mabigat sa bulsa hehehe.
January 13th, 2020 09:24 PM #40
Grats on the good digging, sir![emoji106] This will surely help the BM/BN, 6 & KE owners should bush time come!
SuperPro does have front & rear bushes of the FRONT lower control arm. The rear takes most of the beating. PU won't be as hobo a find, but this will have lifetime warranty the OE can't provide. This pair below is sub $100. The less stressed fronts can go OE.
Because pinoy mentality. Not surprising.
