Results 1,431 to 1,440 of 1510
- Feb 2012
- 27
- Aug 2007
- 22
August 15th, 2017 05:03 PM #14321.) 205/45r17 Kenda Kaiser KR20 on my Daily Driven 2015 Vios. Grip is great in both wet and dry conditions. A little bit noisy on paved roads, though. Highly rated in the US and Japanese Drifting Scene.
2.) 225/45r17 Yokohama Advan Fleva on my 2015 Toyota 86. Well worth the price. Grip is solid on both dry and wet. Parang budget Neova lang na mas mataas treadware rating.
3.) 265/50r20 Accelera Iota on my 2006 Fortuner. Medyo sketchy sa wet, fairly average on dry conditions. Hardly any grip on loose ground.
4.) 195/50r16 Westlake SA37 on my wife's 2016 Accent. Fairly good for a budget tire. Haven't really tested it that much since I rarely use my wife's car, anyway.
Items 1 and 4 I got at Hot Wheels Evangelista. #2 I got at the Yokohama Factory in Severina Village Paranaque and #3 I got at Jhay-M tire supply in Sucat.
- Jan 2016
- 48
August 18th, 2017 02:38 PM #1433Good Day..
Anyone from Montalban Rizal?
I own a toyota vios 3rd gen and my stock tires already needs to be replaced..Any suggestions?
You know well the road condition in Payatas road..
Many Thanks in advance..
Sent from my LG-H818 using Tapatalk
- Nov 2009
- 3,484
October 9th, 2017 11:48 AM #1434Mga ka tsikot, ano po mare recommend nyo from experience, best tread wear & wet grip. Im looking for 195/65R15, OEM is GT Champiro eco - mejo mabilis maupod at madulas kasi. Below selection from budget of P3.3K - 3.6K, branded only:
Yokohama Aspex/Blue Earth
Dunlop LM704
Toyo Proxes/DRB?
TIA
October 9th, 2017 12:10 PM #1435
Napamahal pala ako sa Yoko Aspec, 4k ang bili ko, di kasama ang pito (100*).
- Aug 2017
- 232
October 12th, 2017 05:00 PM #1436Tried to google how to check manufacture date but different siya sa Yokohama Aspec 300 model. Tama ba may nakita akong ehb0707. Is it correct this is the date? Ito lanh nakita ko may 4 numbers.
Sent from my EVA-L19 using Tsikot Forums mobile app
October 17th, 2017 12:15 PM #1437
October 17th, 2017 08:08 PM #1438
Bro, all are good choices. Hardest sidewall belong to the Proxes and DRB as they are entry level sporty tires. Grip is better than OEM. Aspec and Blue Earth are both OEMs so the sidewalls are soft. Tread of the Aspec is a harder compound than the Blue Earth. The LM704 is a touring tire with soft sidewalls typical of Dunlops and better than OEM grip. They tend to pick up nails and such more though.
- Oct 2017
- 182
October 20th, 2017 05:06 AM #1439Hi sirs
Any recommendation for 265/60 r18 ?
Sent from my SM-G950F using Tsikot Forums mobile app
October 20th, 2017 05:07 AM #1440
at or ht or hybrid or mt?
high idle RPM at engine start
