Results 361 to 370 of 1510
- Feb 2009
- 36
March 12th, 2009 11:22 PM #361
- Jun 2008
- 5
March 28th, 2009 03:43 PM #362sir san po ninyo nabili yung achilles platinum, kung may phone number po kayo nung tindahan pwede ko po makuha? thanks!
March 31st, 2009 10:09 AM #363
April 2nd, 2009 04:41 PM #364
yung sa 14's ko eagle f1 gsd3 kinuha ko. 50php lang kasi diperensya sa ducaro ga. It has a higher treadwear 280 compared to 240 of ducaro ga. tapos mas makapit under wet and dry road conditions.
better deal if you get a set of eagle f1's compared to ducaro. the only disadvantage is that the tires squeek sometimes when making a full turn (but I don't find it disturbing)
April 13th, 2009 01:56 PM #365
Fyi: My montero gls se
ben's ok, banawe
price: 94t 4tires with scorpion mags
nitto tires 420s 265/50/20
tire pressure 32front 35rear
travelled 3k km, meron pang buhok sa my thread nya.
Looks better
rides almost same as stock h/t dueller 17''s stiffer but negligible...
- Apr 2009
- 544
April 24th, 2009 02:57 PM #366hi fellow tsikoters...
i use the goodyear fortera 205 /70 ..mahusay ba ito? sino nakagamit na and
ano experience sa use and durability...
and share ko lang sabi ng mechanic ang goodyear tires daw mas hiyang sa mataas na PSI...like 35psi para sa fortera. Totoo ba ito?
thanks
- Aug 2007
- 4
April 25th, 2009 11:17 PM #367
- Aug 2007
- 4
April 25th, 2009 11:43 PM #368tanong ko lang. yun kotcheng may 175/R14 pwede ba palitan ng gulong na 185 /R14? meron ba non? kasi ang concerned ko diba ang tendency na bumagal o mahirapan yun kotche kung di talaga yun ang intended gulong sa sasakyan?
papano ba mag compute ang tolerable specs ng gulong sa isang sasakyan?
- Aug 2007
- 4
April 25th, 2009 11:45 PM #369
- Aug 2007
- 4
April 25th, 2009 11:48 PM #370saan ba magandang bumili ng gulong na average lang? di pang hobbyist? yun general car user lang?
high idle RPM at engine start
